Resultados 1 a 2 de 2
    Avatar de Dexter
    Dexter está offline Smoking tires @7.250rpm
    Sep 2008
    Pombal
    Default Old Top Gear 1990 - Toyota MR2 & Celica GT4
    Smoke tires, not drugs
    Avatar de sparow
    BRAGA
    nem de proposito, andei numas pesquisas e dei com isto:
    http://www.toyotaownersclub.com/foru...showtopic=1518
    Are you after the stats for any particular model as it varies between years, country of origin, model etc....
    Post the model you are after, this might start you off....
    Toyota MR2 Mark I (1985-1989) - UK/Japan
    Dimensions:
    Length 3925mm (154.5")
    Wheelbase 2320mm (91.3")
    Width 1665mm (65.5")
    Height 1250mm (49.2")
    Front track 1440mm (56.7")
    Rear track 1440mm (56.7")
    Ground clearance 140mm (5.5")
    Weight 920kg (2024lb)
    %Weight on front wheels: 44%
    Coefficient of drag: 0.320
    Engine:
    Model: 4A-GE
    Type: DOHC inline-4
    Bore x Stroke: 3.19 x 3.03 in / 81 x 77 mm
    Displacement: 96.8 cu in / 1587cc
    Compression Ratio: 10.0:1
    BHP @ RPM: 124 @ 6500 (pre '88 is 122 @ 6600)
    Torque @ RPM: 110 lb-ft @ 5200 (pre '88 is 105 @ 5000)
    Fuel Injection: MAP sensor based Bosch L-Jetronic
    Fuel Requirement: Unleaded
    Drivetrain:
    Transmission: 5-speed manual
    Gear Ratios:
    5th (0.82): 3.53:1
    4th (0.97): 4.18:1
    3rd (1.31): 5.65:1
    2nd (1.90): 8.19:1
    1st (3.70): 13.66:1
    Final Drive Ratio: 4.13:1
    Acceleration:
    0-100 ft: 3.3 sec
    0-500 ft: 9.1
    0-1320 ft (1/4 mile): 16.9 at 82 mph
    0-30 mph: 3.0
    0-50 mph: 6.7
    0-60 mph: 8.5
    0-70 mph: 12.2
    0-80 mph: 16.0
    0-100 mph: 29.5
    Speed in Gears:
    5th gear (6500 RPM): 120
    4th gear (7700 RPM): 121
    3rd gear (7700 RPM): 87
    2nd gear (7700 RPM): 60
    1st gear (7700 RPM): 37
    Toyota MR2 Mark I - Supercharged (1988 - 1989)
    Dimensions:
    Weight 960kg
    Engine:
    Model: 4A-GZE
    Type: Supercharged DOHC inline-4
    Bore x Stroke:
    Displacement: 1587cc
    Compression Ratio: 8.0:1
    BHP @ RPM: 145 @ 6400
    Torque @ RPM: 140 lb-ft @ 4000 (137lbft @ 4400rpm for J-Spec)
    Fuel Injection:
    Exhaust-Emission Control Equipment: 3-way catalytic converter, oxygen sensor
    Drivetrain:
    Gear Ratios:
    5th: 0.73:1
    4th: 0.92:1
    3rd: 1.26:1
    2nd: 1.91:1
    1st: 3.32:1
    Final Drive Ratio: 4.29:1
    Acceleration:
    0-100 ft: 3.0
    0-500 ft: 8.5
    0-1320 ft (1/4 mile): 15.8 at 86.7 mph
    0-30 mph: 2.0
    0-50 mph: 5.3
    0-60 mph: 6.5 - 6.8
    0-70 mph: 10.1
    0-80 mph: 12.8
    0-100 mph: 21.5
    Speed in Gears:
    5th gear (Rev Limiter): 130mph (est)
    4th gear ( RPM):
    3rd gear ( RPM):
    2nd gear ( RPM):
    1st gear ( RPM):
    Toyota MR2 - MKII Coupe (1989 - 1991)
    Dimensions:
    Length: 4170mm
    Width: 1700mm
    Height: 1240mm
    Wheel Base = 2400mm
    Front Track = 1470mm
    Rear Track = 1450mm
    Ground Clearance: 135mm
    Coefficient of drag: 0.310
    Weight: 1145kg
    %Weight on front wheels: 42%
    Engine:
    Model: 3S-FE
    Type: DOHC inline-4
    Bore x Stroke: 3.39 x 3.39 in, 86.9 x 86.0mm
    Displacement: 1998cc
    Compression Ratio: 9.8:1
    BHP @ RPM: 119 @ 5600
    Torque @ RPM: 130 @ 4400
    Fuel Injection: Toyota Electronic with port injection
    Drivetrain:
    Gear Ratios:
    5th:
    4th:
    3rd:
    2nd:
    1st:
    Final Drive Ratio:
    Acceleration:
    0-100 ft:
    0-500 ft:
    0-30 mph:
    0-50 mph:
    0-60 mph: 9.5
    0-70 mph:
    0-80 mph:
    0-100 mph:
    Speed in Gears:
    5th gear ( RPM): 124mph
    4th gear ( RPM):
    3rd gear ( RPM):
    2nd gear ( RPM):
    1st gear ( RPM):
    Toyota MR2 - MKII - North America (1991 - 1992)
    Dimensions:
    Length: 4170mm
    Width: 1700mm
    Height: 1240mm
    Wheel Base = 2400mm
    Rear Track = 1450mm
    Engine:
    Model: 5S-FE
    Type: Normally Aspirated
    Bore x Stroke:
    Displacement: 2164cc
    Compression Ratio: 9.5:1
    BHP @ RPM: 130 @ 5400
    Torque @ RPM: 140lb-ft @ 4400
    Fuel Injection: Electronic Fuel Injection
    Drivetrain:
    Transmission: 5-speed manual S54
    Gear Ratios:
    5th: 0.820
    4th: 1.028
    3rd: 1.322
    2nd: 1.960
    1st: 3.285
    Final Drive Ratio: 4.176
    Acceleration:
    0-100 ft: 3.2
    0-500 ft: 8.9
    0-1320 ft (1/4 mile): 16.5 at 84.4 mph
    0-30 mph: 2.3
    0-50 mph: 5.9
    0-60 mph: 8.7
    0-70 mph: 11.1
    0-80 mph: 14.9
    0-100 mph: 24.9
    Speed in Gears:
    5th gear (Rev Limiter): 126mph
    4th gear (6300 RPM): 100.5
    3rd gear (6300 RPM): 78.1
    2nd gear (6300 RPM): 52.7
    1st gear (6300 RPM): 31.4
    Toyota MR2 - MKII N/A (1989 - 1991)
    Dimensions:
    Length: 4170mm
    Width: 1700mm
    Height: 1240mm
    Wheel Base = 2400mm
    Rear Track = 1450mm
    Weight: 1210kg
    Engine:
    Model: 3S-GE
    Type: DOHC 16v
    Bore x Stroke:
    Compression Ratio:
    BHP @ RPM: 158 @ 6600
    Torque @ RPM: 140 @ 4800
    Fuel Injection: Multipoint
    Exhaust-Emission Control Equipment: oxygen sensor
    Drivetrain:
    Gear Ratios:
    5th: 0.820
    4th: 1.028
    3rd: 1.322
    2nd: 1.960
    1st: 3.285
    Final Drive Ratio: 3.944
    Acceleration:
    0-100 ft:
    0-500 ft:
    0-30 mph: 2.8
    0-50 mph:
    0-60 mph: 7.2
    0-70 mph:
    0-80 mph:
    0-100 mph: 20.8
    Speed in Gears:
    5th gear (6500 RPM): 142mph
    4th gear (7000 RPM): 122mph
    3rd gear (7000 RPM): 98mph
    2nd gear (7000 RPM): 67mph
    1st gear (7000 RPM): 40mph
    Toyota MR2 - MKII N/A (1991 - 1994)
    Dimensions:
    Length: 4170mm
    Width: 1700mm
    Height: 1240mm
    Wheel Base = 2400mm
    Rear Track = 1450mm
    Engine:
    Model: 3S-GE
    Type: DOHC 16v
    Bore x Stroke:
    Exhaust-Emission Control Equipment: 3-way catalytic convertor, oxygen sensor
    Drivetrain:
    Gear Ratios:
    5th: 0.820
    4th: 1.028
    3rd: 1.322
    2nd: 1.960
    1st: 3.285
    Acceleration:
    0-100 ft:
    0-500 ft:
    0-30 mph:
    0-50 mph:
    0-60 mph:
    0-70 mph: 7.2
    0-80 mph:
    0-100 mph: 20.8
    Speed in Gears:
    Toyota MR2 - MKII N/A (1994+)
    Dimensions:
    Length: 4170mm
    Width: 1700mm
    Height: 1235mm
    Wheel Base = 2400mm
    Rear Track = 1450mm
    Ground Clearance: 130mm
    Engine:
    Model: 3S-GE
    Type: 2.0L DOHC 16v with ACIS
    Bore x Stroke: 86 x 86
    Compression Ratio: 10.3:1
    BHP @ RPM: 174 @ 7000
    Torque @ RPM: 140 lbft @ 4800
    Drivetrain:
    Gear Ratios:
    5th:
    4th:
    3rd:
    2nd:
    1st:
    Final Drive Ratio:
    Acceleration:
    0-100 ft:
    0-500 ft:
    0-30 mph:
    0-50 mph:
    0-60 mph: 7.7
    0-70 mph:
    0-80 mph:
    0-100 mph:
    Speed in Gears:
    5th gear ( RPM): 137
    4th gear ( RPM):
    3rd gear ( RPM):
    2nd gear ( RPM):
    1st gear ( RPM):
    ACIS - Acoustic Control Induction System - varies the flow of air into the engine to give improved performance under different driving conditions
    Toyota MR2 - MKII Turbo (1989 - 1994)
    Dimensions:
    Length: 4170mm
    Width: 1700mm
    Height: 1240mm
    Wheel Base = 2400mm
    Rear Track = 1450mm
    Engine:
    Model: 3S-GTE
    Type: DOHC 16v Turbocharged
    Bore x Stroke: 86.0 x 86.0
    Compression Ratio: 8.8:1
    BHP @ RPM: 220 @ 6000 (200bhp @ 6000rpm for US model)
    Torque @ RPM: 200 lb-ft @ 3200
    Fuel Injection: Nippondenso Multipoint Electronic
    Fuel Requirement: (Super) Unleaded
    Drivetrain:
    Transmission: 5-speed manual, double-overdrive
    Gear Ratios:
    5th: 3.23:1
    4th: 1.91:1
    3rd: 1.32:1
    2nd: 0.92:1
    1st: 0.73:1
    Acceleration:
    0-100 ft: 2.9
    0-500 ft: 7.9
    0-1320 ft (1/4 mile): 14.7 @ 94.3 mph
    0-30 mph: 1.8
    0-40 mph: 3.3
    0-50 mph: 4.5
    0-60 mph: 6.2
    0-70 mph: 8.3
    0-80 mph: 10.3
    0-90 mph: 13.6
    0-100 mph: 16.5
    Speed in Gears:
    5th gear (6650 RPM): 145 mph
    4th gear (7000 RPM): 125
    3rd gear (7000 RPM): 91
    2nd gear (7000 RPM): 60
    1st gear (7000 RPM): 35
    Toyota MR2 MKII Turbo (1994+)
    Dimensions:
    Length: 4170mm
    Width: 1700mm
    Height: 1235mm
    Wheel Base = 2400mm
    Rear Track = 1450mm
    Engine:
    Model: 3S-GTE
    Type: Turbocharged DOHC 16v
    Bore x Stroke:
    Compression Ratio: 8.5:1
    BHP @ RPM: 245 @ 6000
    Torque @ RPM: 224 lbft @ 4000
    Fuel Injection:
    Drivetrain:
    Gear Ratios:
    5th:
    4th:
    3rd:
    2nd:
    1st:
    Final Drive Ratio:
    Acceleration:
    0-100 ft:
    0-500 ft:
    0-30 mph:
    0-40 mph:
    0-60 mph:
    0-70 mph:
    0-80 mph:
    0-100 mph:
    Speed in Gears:
    5th gear ( RPM):
    4th gear ( RPM):
    3rd gear ( RPM):
    2nd gear ( RPM):
    1st gear ( RPM):
    Toyota MR2 MKIII or MR-S or Spyder or ZZ30 (1999+)
    Dimensions:
    Length: 153.0 inches / 3885mm
    Width: 66.7 / 1685mm
    Height: 48.8 / 1240mm (s/top) - 49.2 / 1250mm (h/top)
    Ground Clearance: 5.5 / 140mm
    Wheelbase: 96.5 / 2450mm
    Tyres: Front - 185/55 R15, Rear - 205/50 R15
    Turning Circle: 5.0m / 16.4ft
    Luggage Space: 0.09 cubic metres
    Coefficent of Drag (Cd):0.35
    Kerb Weight: 975 - 1015kg
    Gross Vehicle Weight: 1225kg
    Engine:
    Model:
    Type: Inline 4-cylinder, DOHC, 4 valve/cylinder VVT-i (Variable Valve Timing with intelligence)
    Bore x Stroke: 79.0 x 91.5
    Displacement: 1794cc
    BHP @ RPM: 138 @ 6400
    Torque @ RPM: 127 lb-ft @ 4200
    Fuel Injection: Multi-point Electronic
    Tank Capacity: 48 litres / 10.6 gallons
    Fuel Consumption: 28 - 49.9 mpg
    CO2 emission: 178g/km
    Drivetrain:
    Transmission: 5-speed manual with overdrive
    Gear Ratios:
    5th:
    4th:
    3rd:
    2nd:
    1st:
    Final Drive Ratio:
    Acceleration:
    0-100 ft:
    0-500 ft:
    0-30 mph:
    0-50 mph:
    0-62 mph: 8.0 seconds
    0-70 mph:
    0-80 mph:
    0-100 mph:
    Speed in Gears:
    5th gear ( RPM): 129mph
    4th gear ( RPM):
    3rd gear ( RPM):
    2nd gear ( RPM):
    1st gear ( RPM):
Tags for this Thread
