Pág 1 de 3 123 ÚltÚlt
Resultados 1 a 30 de 65
    AlexM2000 está offline BANIDO!
    Oct 2008
    Lisboa
    Thumbs up Clientes exigem pedal novo.
    Depois da marca ter sido acusada de ter reagido tarde a este problema, eis que surge outro, centenas de clientes estão a exigir um pedal novo, estes não querem as suas viaturas com remendos!
    "Toyota deal with two options, one is to just put in a new pedal, the second is to add a steel bar to the bottom of the pedal"
    Muitos acusam a Toyota de ter optado por uma solução que em nada dignifica a marca.
    Nesta situação a Toyota deveria substituir o pedal, e não andar a colocar remendos, o que por sí só aumenta o grau de desconfiança dos seus clientes.
    "Toyota is following a quick and dirty path to a recall with the steel bar...
    But this does not convince non-experts, especially when Toyota has been so slow to react to the problems. So, it seems Toyota should go with the new pedal solution for everyone. Why aren’t they doing that?"
    Parece que mais cedo ou mais tarde a marca vai ser obrigada a substituir o pedal.
    "The steel bars can be produced more quickly than the new pedals. Toyota would like to get the cars on the road fixed as soon as possible to avoid another crash. So, it has decided to go for a fix which is fast but looks suspicious. This is the problem."
    "It has to try to make the solution as “above-the-board” as possible. Perhaps announce that anyone who got the steel bar can get the new pedal later in the year if they are not happy. If Toyota really believes the steel bar fix is as good as a new pedal, it should give away something free and valuable to make the solution credible and to say “we are sorry”. People wanting the new pedal should not get the freebie."
    Aqui está um tópico que se quer claro e objectivo.
    Lá fora os clientes estão a exigir um pedal novo.
    A marca deve ou não colocar um pedal novo?
    Última edição de AlexM2000 : 08-02-2010 às 09:28 AM Razão: problema pedal
    Avatar de Vangelis
    Vangelis está offline Senior Member
    Oct 2009
    Águas Santas
    Olá,
    Esperemos que a mentalidade Chinesa não ataque o Japão !!!
    É lógico que ninguem gosta de remendos !!!
    Abraços.
    Última edição de Vangelis : 08-02-2010 às 10:04 AM
    Avatar de Duarte
    Jul 2005
    Cartaxo
    Mas existem remendos e coisas feitas em condições, afinal os eng. da Toyota não devem andar a dormir depois desta barraca toda. Claro que um pedal novo (desde que não venha tb a dar chatices é sempre bem vido.
    Quem quizer um pedal novo não leva o brinde
    Avatar de Vangelis
    Oct 2009
    Águas Santas
    Quote Mensagem Original de Duarte Ver Mensagem
    Esperemos bem que não !!!
    Por mim, já adaptei um fio ao pedal ... se este ficar preso é só puxar o fio !!!
    Oct 2008
    Lisboa
    Mas existem remendos e coisas feitas em condições, afinal os eng. da Toyota não devem andar a dormir depois desta barraca toda.l
    Pelo que tenho lido, acho que os mesmos andam a dormir faz tempo, esta solução de remendo não foi nada feliz.
    Avatar de Saturn_Guardian
    Saturn_Guardian está offline Senior Member
    Belas
    Que drama, isto só deu problemas em muito poucos carros para não dizer raros.
    Mas como falamos da TOYOTA eles detectaram que existe uma possibilidade de acontecer esse problema,
    e mais uma vez como TOYOTA é TOYOTA eles vão chamar todos os que podem ter esse problema e vão resolver.
    O Yaris da minha irmã supostamente vai ser chamado e não é por isso que tenho menos confiança em andar nele.
    Com o tempo tudo se vai resolver tenham é paciência.
    Corolla E12 Facelift HB 5p Sol 1.4 VVT-i 30/03/2005 - 09/11/2006 - 35048km
    Honda Civic VIII 5p 1.4 i-DSI Sport 05/02/2007 - 74700km
    DoriftoKingu está offline BANIDO!
    Jan 2010
    Quote Mensagem Original de Vangelis Ver Mensagem
    Olá,
    Abraços.
    Estamos num Mundo onde actualmente é Tudo "Made in China", os pedais até podem ser PRODUZIDOS ou MONTADOS pela CST, mas os materiais é tudo "Made in China". Estes gajos vão destruir o Mundo! Ou não.. Aqui fica a questão!
    Mas na minha opinião a TOYOTA devería substituir os pedais. Era o mais sensato para a Imagem da Construtora.
    Oct 2008
    Lisboa
    Quote Mensagem Original de Saturn_Guardian Ver Mensagem
    Drama está a fazer a Toyota, em vez de substituírem o pedal e acabarem de uma vez por todas com este problema , não!
    Arranjaram esta solução à presa e barata, mas têm algum jeito colocar remendos no carro, quando o problema é o pedal que apresenta uma folga.
    Mais uma vez, "money talks", a Toyota a tentar poupar tostões com esta solução manhosa.
    E se a peca se soltar, como é?
    Vão recolher de novo os 8 milhões de carros?
    Avatar de telmo.salgado
    Jul 2006
    Quote Mensagem Original de AlexM2000 Ver Mensagem
    Solução manhosa?? Esse adjectivo é muito exagerado, Alex. Conheces bem a solução, achas que aquilo pode falhar?
    Então explica lá, somos todos ouvidos. Aliás, há muitos engenheiros a dormir na Toyota, vamos acordá-los com a tua descrição da falha que pode acontecer.
    Land Cruiser'80
    CarinaE'93
    Prius'10
    Oct 2008
    Lisboa
    Telmo, como é obvio a melhor solução é substituir o pedal.
    Cala-se a opinião pública, o cliente fica com um pedal novo e não com um pedal com defeito mais remendo, esta é a realidade da questão. No subconsciente fica a questão, o meu carro têm um defeito no pedal e não o substituíram a fim de se poupar dinheiro, mais uma vez.
    A marca teve que agir rápido, e fê-lo de uma forma que está a gerar a maior confusão, são aos milhares os clientes que exigem um pedal novo, achas que a marca ganha alguma coisa com isso, só se enterra ainda mais.
    Se o tribunal nos Estados Unidos der razão aos clientes, já imaginaste a barraca qua vai ser.
    Ambos sabemos que produzir pedais é mais carro do que uma simples peca de metal, o tempo de substituição também é consideravelmente maior, também sabemos que os accionistas querem conter os custos ao máximo, visto a probabilidade da folga no pedal provocar um acidente ser praticamente zero, mas poxa, trata-se de ganhar a confiança de muito analfabruto que por ai anda.
    Imagina a medida que a Toyota apresentou aos seus clientes ser considerada nula, que a marca têm de substituir o pedal.
    É que o tombo é cada vez maior.
    Hoje já vi uma satira na CBS onde colocavam pastilha elastica, em vez da peça de metal... gozo total.
    Jul 2006
    Parece óbvio então que tecnicamente não há outra opção que não seja a aplicação da peça em metal ou a substituição do sistema.
    O que é preocupante é que algumas pessoas que percebem menos do assunto assumem posições sobre questões que não conhecem.
    É um pouco como a gripeA, das 100 pessoas que morreram em Portugal, muitas negaram tomar vacina, por desconhecimento, manipulação de opinião pública e até negligência médica.
    Se a Toyota for obrigada a fornecer pedais novos, o problema pode persistir nos veículos que circulam enquanto os pedais novos não chegarem (8 milhões de peças completas não se fazem numa semana).
    Se calhar esta fobia prova que afinal a sensação de insegurança não é assim tão grande. Ou que todos os Toyota afectados estão parados neste entretanto!
    Pessoalmente, só tenho a dizer que já não estranho as tuas posições sobre determinados assuntos, mas parece-me evidente que neste assunto cais no mesmo erro ao incorporar opiniões de terceiros que não têm mais que fazer que conjecturar nos media com objectivos nebulosos ou até dolosos.
    Land Cruiser'80
    CarinaE'93
    Prius'10
    Oct 2008
    Lisboa
    Telmo, como me considero uma pessoa informada, estou perfeitamente à vontade a conduzir o meu Toyota Auris, apesar de saber que o mesmo pode estar equipado com um pedal com defeito, o que por sí só não é uma ideia nada agradável, especialmente vindo de uma marca que sempre primou pela qualidade dos seus produtos.
    Como deves calcular a minha opinião sobre a Toyota têm-se vindo a degradar com base em experiências pessoais e estes últimos acontecimentos mundiais só vêm reforçar a minha opinião de que a marca se desleixou e está a perder a sua qualidade geral em vários aspectos, o uso de fornecedores onde a política de aquisição é duvidosa é disso um bom exemplo.
    Que ninguém se engane aqui, a empresa que fornece ou fornecia os pedais para a Toyota fê-lo com base na melhor proposta apresentada, trocando isto por miúdo, foi de longe a proposta mais barata e o resultado está a vista. No dia que fores Presidente, gestor ou accionista numa empresa como a Toyota vais aprender muito, uma coisa é a lenga lenga que as empresas passam cá para fora, outra é aquilo que realmente fazem, trabalho numa grande empresa que transmite um cenário aos seus clientes que não o têm, e não me vou alongar muito nesta matéria, para bom entendedor meia palavra basta.
    Quando o próprio chefe máximo da Toyota anuncia que vai criar um novo departamento de qualidade chefiado directamente por ele, está indirectamente a culpabilizar o que já existe.
    Não preciso de ler a opinião de terceiros para perceber muito bem aquilo que se passa. A Toyota sempre foi uma empresa a abater e cá tens um óptimo exemplo disso.
    Agora que a marca se deixou dormir, deixou e o resultado está à vista, mas cabe na cabeça de alguém, nos dias de hoje um carro novo receber 3 estrelas Euro Ncap, isto é apenas um pequeno exemplo da inúmeras falhas que a empresa apresenta actualmente.
    Agora se me perguntarem se quero um remendo no carro, ou um pedal novo, nem vou pensar duas vezes. Pedal novo na hora.
    A Toyota só esta a colher aquilo que plantou.
    Tenho um Toyota e provavelmente a minha próxima viatura vai ser um Toyota, agora não tenho é duas palas nos olhos.
    Jul 2006
    Pois, na prática ainda não entendeste muito bem a técnica do problema do pedal. Mas isso adiante, ninguém é obrigado a conhecer, isso só os engenheiros da Toyota. Eu porém, segui os links e visualizei o funcionamento, percebendo que não se trata de folga, e que o troço de metal que se propõem é adequado e propositado.
    Quanto à gestão duma grande empresa, convém reconhecer os méritos da Toyota em escolher um fornecedor AMERICANO para os seus pedais - contribuiu para a mão-de-obra local, e para a criação de valor em solo americano. Se isso era a melhor oferta económica, pelo menos tinha estes acréscimos. A qualidade americana não chega? E eles virem dizer que seguiram à risca o projecto e as tolerâncias dadas pela Toyota. Tê-las-hão questionado? Eu acho que não, pelo facto dos mesmos pedais produzidos no Japão aparentemente não terem dado problemas.
    No teu úiltimo post colocaste aqui outros problemas da Toyota, como o 3 estrelas na EuroNCap do Urban. Eu achava melhor não misturar as coisas. Aqui fala-se de pedal. Critico-te Alex, quando tornas abrangente um assunto específico como este, com opinião formada por terceiros.
    Land Cruiser'80
    CarinaE'93
    Prius'10
    Oct 2008
    Lisboa
    Telmo estamos cá para discutir os assuntos na boa, podes me criticar à vontade... é saudável assimilar outros pontos de vista.
    Agora eu estou no meu pleno direito de não querer um remendo no meu carro, o pedal têm um defeito já assumido pela marca.
    Eu não sou obrigado a aceitar a solução deles, por lei são obrigados a substituir a peça, não a colocar remendos.
    Uma coisa é o cliente estragar o pedal, outra é este vir defeituoso de origem.
    Neste clima de suspeita mundial, acho que a Toyota não vai levantar muitas ondas.
    Jul 2006
    Ok, tudo bem sobre os pontos de vista. Admito que por vezes me excedo, o que desde já peço desculpa.
    Em relação ao pedal que é o que nos traz aqui: se fosse um risco numa porta, pedias uma porta nova? E o cliente pode pedir um pedal novo quando o que está em causa é um atrito entre as superfícies de contacto e o eixo do pedal?
    Land Cruiser'80
    CarinaE'93
    Prius'10
    Oct 2008
    Lisboa
    Garanto que se o carro viesse com a porta riscada ia de vela, não o aceitava.
    O pedal vêm com um defeito de origem, não sou obrigado a aceitar uma solução que serve claramente os interesses da marca.
    É simples, gostem ou não, não aceito. Se noutros países estão a substituir o pedal a quem reclama, não é cá que a vai ser diferente, durante anos andaram a gozar com o cliente, agora chegou a minha vez.
    Mas agora a Toyota já manda no meu carro?
    Avatar de TiZeDasCoives
    TiZeDasCoives está offline Senior Member
    Já não percebo nada...
    Mas afinal já há um pedal actualizado ou não?
    Legalizem o Furão!!!
    "Eu também acelerava, mas ela é tão grande que trava-me o carro sozinha" by TiZeDasCoives
    Oct 2008
    Lisboa
    Quote Mensagem Original de TiZeDasCoives Ver Mensagem
    Existe um remendo!
    Uma peça de metal que se coloca para anular a folga existente.
    Oh alex , vamos a ver uma coisa.. Isso que falas ser uma peça de metal é o que ? ..vamos chamar nomes as coisas..
    imagina tu que é um parafuso de uma liga manhosa que nao consegue dar aperto nessa "peca de metal " que chamaste .. Achas que é preciso trocar a peca toda de metal , estando ela boa ou entao mais rapido e igualmente correctivo trocar o parafuso por um bom ??
    Para mim , se bem entendi a parte da situacao do pedal , deve ser uma folga que um casquilho ganhou no eixo de rotacao do pedal do acelerador . Deve ser feito de nylon ou rylene , e nao de aço , ou inox por exemplo.. Se o resultado for igual , troca-se o casquilho e nao a peça de metal ( como tu lhe chamaste ) toda nova .
    Mas mais de metade das pessoas nao entende isso .. Existe uma acção correctiva para uma medida de nao conformidade. Essa acçao tem que ter efeitos a 100 % para nao se tornar efectiva outra vez.. Se eles optaram por colocar " um remendo " tenho a certeza que resolve o problema , senao nao o fariam desta forma. Mas como o povinho é certo de satirizar , ja se estava a espera de uma satira , comedia por parte dos media.
    Gostava que alguem pusesses nomes os nomes aos " remendos " e " peça de metal " para se saber realmente o que se esta a falar .
    Avatar de Vangelis
    Oct 2009
    Águas Santas
    Olá Nuno,
    Gostei da lógica com que abordaste este tema!
    Realmente deve-se separar o trigo do joio ... e segundo a tua explicação não há necessidade de substituir todo o conjunto!
    Abraço.
    Existe um remendo!
    Então queres um pedal novo porque?
    Das duas, três, ou vem com o mesmo defeito, ou então vem com o tal remendo...
    Avatar de CrasyE12
    Aug 2008
    Vialonga
    é novo com o remendo
    O meu carrito :
    Oct 2008
    Lisboa
    Fora de brincadeiras , quero um pedal novo, daqueles made in Japan e não made in USA.
    Tão simples como isto.
    Mas quem é que estava a brincar ?.. eu estava a falar a serio..
    Apr 2006
    O meu foi provavelmente o primeiro ou dos primeiros a levar com a solução no pedal.
    Fui busca-lo hoje e já está resolvido, levou o dito "calço".
    Para mim serve, o que conta é não ter problemas por causa disso!
    P@co D-4D
    E quando fores reclamar eles vão dizer-te aquilo que queres ouvir... "sim sim, o pedal veio directamente do japão" quando eles realmente queriam dizer "sim sim, vais comer com um pedal remendado como os outros todos"!
    Avatar de Vangelis
    Oct 2009
    Águas Santas
    Ó pá, mas isso não se chama "remendo", mas sim: "UPGRADE" ao pedal !
    Desde que não corra o risco de entrar por um galinheiro a dentro a 160 km / hora ... por mim podem fazer o tal upgrade à vontade
    Oct 2008
    Lisboa
    Infelizmente é assim que se trabalha em Portugal, é por isso que este país não anda para a frente.
    Avatar de enrike552
    enrike552 está offline Senior Member
    Jun 2008
    Por Aí
    Eu já deixei o aviso que se o pedal prender o primeiro muro é o destino do carro, para receber indemnização. Isto falado com o pessoal da recepção da SC.
    No entanto até agora nao deu problemas.
  30. #30
    Avatar de Supra MKIII
    Supra MKIII está offline O Bino mais velho da ART!
    Oct 2005
    Porto
    Então nesse caso perdes um pouco a moral para fazer tanta critica.
    Isto.
    Aliás é mais um fruto da honestidade da marca, pois se tivessem dito aos media que iam trocar por pedais todos novos em vez de os repararem já não havia tanto barulho.
    Alex faço-te uma pergunta, imagina que em vez de um pedal o defeito de fabrico era no bloco do motor. Ias obrigar a marca a substituir só o bloco ou o motor completo?
    "Kit d'unhas não se compra... nasce-se com ele!!!"
Tags for this Thread
