Resultados 1 a 11 de 11
Tópico: Códigos de avaria OBDII Toyota Corolla
    Feb 2001
    Leiria
    Default Códigos de avaria OBDII Toyota Corolla
    Diagnostic Codes - Toyota
    On-Board Diagnostics II OBDII
    OBD II TROUBLE CODES
    P0100 Mass or Volume Air Flow Circuit Malfunction
    P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
    P0102 Mass or Volume Air Flow Circuit Low Input
    P0103 Mass or Volume Air Flow Circuit High Input
    P0104 Mass or Volume Air Flow Circuit Intermittent
    P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
    P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
    P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
    P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
    P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
    P0110 Intake Air Temperature Circuit Malfunction
    P0111 Intake Air Temperature Circuit Range/Performance Problem
    P0112 Intake Air Temperature Circuit Low Input
    P0113 Intake Air Temperature Circuit High Input
    P0114 Intake Air Temperature Circuit Intermittent
    P0115 Engine Coolant Temperature Circuit Malfunction
    P0116 Engine Coolant Temperature Circuit Range/Performance Problem
    P0117 Engine Coolant Temperature Circuit Low Input
    P0118 Engine Coolant Temperature Circuit High Input
    P0119 Engine Coolant Temperature Circuit Intermittent
    P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Malfunction
    P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem
    P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input
    P0123 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input
    P0124 Throttle/Pedal Position Sensor/Switch "A" Circuit Intermittent
    P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control
    P0126 Insufficient Coolant Temperature For Stable Operation
    P0130 O2Circuit Malfunction (Bank #1 Sensor #1)
    P0131 O2Sensor Circuit Low Voltage (Bank #1 Sensor #1)
    P0132 O2Sensor Circuit High Voltage (Bank #1 Sensor #1)
    P0133 O2Sensor Circuit Slow Response (Bank #1 Sensor #1)
    P0134 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #1)
    P0135 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #1)
    P0136 O2Sensor Circuit Malfunction (Bank #1 Sensor #2)
    P0137 O2Sensor Circuit Low Voltage (Bank #1 Sensor #2)
    P0138 O2Sensor Circuit High Voltage (Bank #1 Sensor #2)
    P0139 O2Sensor Circuit Slow Response (Bank #1 Sensor #2)
    P0140 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #2)
    P0141 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #2)
    P0142 O2Sensor Circuit Malfunction (Bank #1 Sensor #3)
    P0143 O2Sensor Circuit Low Voltage (Bank #1 Sensor #3)
    P0144 O2Sensor Circuit High Voltage (Bank #1 Sensor #3)
    P0145 O2Sensor Circuit Slow Response (Bank #1 Sensor #3)
    P0146 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #3)
    P0147 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #3)
    P0150 O2Sensor Circuit Malfunction (Bank #2 Sensor #1)
    P0151 O2Sensor Circuit Low Voltage (Bank #2 Sensor #1)
    P0152 O2Sensor Circuit High Voltage (Bank #2 Sensor #1)
    P0153 O2Sensor Circuit Slow Response (Bank #2 Sensor #1)
    P0154 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #1)
    P0155 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #1)
    P0156 O2Sensor Circuit Malfunction (Bank #2 Sensor #2)
    P0157 O2Sensor Circuit Low Voltage (Bank #2 Sensor #2)
    P0158 O2Sensor Circuit High Voltage (Bank #2 Sensor #2)
    P0159 O2Sensor Circuit Slow Response (Bank #2 Sensor #2)
    P0160 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #2)
    P0161 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #2)
    P0162 O2Sensor Circuit Malfunction (Bank #2 Sensor #3)
    P0163 O2Sensor Circuit Low Voltage (Bank #2 Sensor #3)
    P0164 O2Sensor Circuit High Voltage (Bank #2 Sensor #3)
    P0165 O2Sensor Circuit Slow Response (Bank #2 Sensor #3)
    P0166 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #3)
    P0167 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #3)
    P0170 Fuel Trim Malfunction (Bank #1)
    P0171 System Too Lean (Bank #1)
    P0172 System Too Rich (Bank #1)
    P0173 Fuel Trim Malfunction (Bank #2)
    P0174 System Too Lean (Bank #2)
    P0175 System Too Rich (Bank #2)
    P0176 Fuel Composition Sensor Circuit Malfunction
    P0177 Fuel Composition Sensor Circuit Range/Performance
    P0178 Fuel Composition Sensor Circuit Low Input
    P0179 Fuel Composition Sensor Circuit High Input
    P0180 Fuel Temperature Sensor "A" Circuit Malfunction
    P0181 Fuel Temperature Sensor "A" Circuit Range/Performance
    P0182 Fuel Temperature Sensor "A" Circuit Low Input
    P0183 Fuel Temperature Sensor "A" Circuit High Input
    P0184 Fuel Temperature Sensor "A" Circuit Intermittent
    P0185 Fuel Temperature Sensor "B" Circuit Malfunction
    P0186 Fuel Temperature Sensor "B" Circuit Range/Performance
    P0187 Fuel Temperature Sensor "B" Circuit Low Input
    P0188 Fuel Temperature Sensor "B" Circuit High Input
    P0189 Fuel Temperature Sensor "B" Circuit Intermittent
    P0190 Fuel Rail Pressure Sensor Circuit Malfunction
    P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
    P0192 Fuel Rail Pressure Sensor Circuit Low Input
    P0193 Fuel Rail Pressure Sensor Circuit High Input
    P0194 Fuel Rail Pressure Sensor Circuit Intermittent
    P0195 Engine Oil Temperature Sensor Malfunction
    P0196 Engine Oil Temperature Sensor Range/Performance
    P0197 Engine Oil Temperature Sensor Low
    P0198 Engine Oil Temperature Sensor High
    P0199 Engine Oil Temperature Sensor Intermittent
    P0200 Injector Circuit Malfunction
    P0201 Injector Circuit Malfunction — Cylinder #1
    P0202 Injector Circuit Malfunction — Cylinder #2
    P0203 Injector Circuit Malfunction — Cylinder #3
    P0204 Injector Circuit Malfunction — Cylinder #4
    P0205 Injector Circuit Malfunction — Cylinder #5
    P0206 Injector Circuit Malfunction — Cylinder #6
    P0207 Injector Circuit Malfunction — Cylinder #7
    P0208 Injector Circuit Malfunction — Cylinder #8
    P0209 Injector Circuit Malfunction — Cylinder #9
    P0210 Injector Circuit Malfunction — Cylinder #10
    P0211 Injector Circuit Malfunction — Cylinder #11
    P0212 Injector Circuit Malfunction — Cylinder #12
    P0213 Cold Start Injector #1 Malfunction
    P0214 Cold Start Injector #2 Malfunction
    P0215 Engine Shutoff Solenoid Malfunction
    P0216 Injection Timing Control Circuit Malfunction
    P0217 Engine Over Temperature Condition
    P0218 Transmission Over Temperature Condition
    P0219 Engine Over Speed Condition
    P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Malfunction
    P0221 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance Problem
    P0222 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input
    P0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input
    P0224 Throttle/Pedal Position Sensor/Switch "B" Circuit Intermittent
    P0225 Throttle/Pedal Position Sensor/Switch "C" Circuit Malfunction
    P0226 Throttle/Pedal Position Sensor/Switch "C" Circuit Range/Performance Problem
    P0227 Throttle/Pedal Position Sensor/Switch "C" Circuit Low Input
    P0228 Throttle/Pedal Position Sensor/Switch "C" Circuit High Input
    P0229 Throttle/Pedal Position Sensor/Switch "C" Circuit Intermittent
    P0230 Fuel Pump Primary Circuit Malfunction
    P0231 Fuel Pump Secondary Circuit Low
    P0232 Fuel Pump Secondary Circuit High
    P0233 Fuel Pump Secondary Circuit Intermittent
    P0234 Engine Over Boost Condition
    P0261 Cylinder #1 Injector Circuit Low
    P0262 Cylinder #1 Injector Circuit High
    P0263 Cylinder #1 Contribution/Balance Fault
    P0264 Cylinder #2 Injector Circuit Low
    P0265 Cylinder #2 Injector Circuit High
    P0266 Cylinder #2 Contribution/Balance Fault
    P0267 Cylinder #3 Injector Circuit Low
    P0268 Cylinder #3 Injector Circuit High
    P0269 Cylinder #3 Contribution/Balance Fault
    P0270 Cylinder #4 Injector Circuit Low
    P0271 Cylinder #4 Injector Circuit High
    P0272 Cylinder #4 Contribution/Balance Fault
    P0273 Cylinder #5 Injector Circuit Low
    P0274 Cylinder #5 Injector Circuit High
    P0275 Cylinder #5 Contribution/Balance Fault
    P0276 Cylinder #6 Injector Circuit Low
    P0277 Cylinder #6 Injector Circuit High
    P0278 Cylinder #6 Contribution/Balance Fault
    P0279 Cylinder #7 Injector Circuit Low
    P0280 Cylinder #7 Injector Circuit High
    P0281 Cylinder #7 Contribution/Balance Fault
    P0282 Cylinder #8 Injector Circuit Low
    P0283 Cylinder #8 Injector Circuit High
    P0284 Cylinder #8 Contribution/Balance Fault
    P0285 Cylinder #9 Injector Circuit Low
    P0286 Cylinder #9 Injector Circuit High
    P0287 Cylinder #9 Contribution/Balance Fault
    P0288 Cylinder #10 Injector Circuit Low
    P0289 Cylinder #10 Injector Circuit High
    P0290 Cylinder #10 Contribution/Balance Fault
    P0291 Cylinder #11 Injector Circuit Low
    P0292 Cylinder #11 Injector Circuit High
    P0293 Cylinder #11 Contribution/Balance Fault
    P0294 Cylinder #12 Injector Circuit Low
    P0295 Cylinder #12 Injector Circuit High
    P0296 Cylinder #12 Contribution/Balance Fault
    P0300 Random/Multiple Cylinder Misfire Detected
    P0301 Cylinder #1 — Misfire Detected
    P0302 Cylinder #2 — Misfire Detected
    P0303 Cylinder #3 — Misfire Detected
    P0304 Cylinder #4 — Misfire Detected
    P0305 Cylinder #5 — Misfire Detected
    P0306 Cylinder #6 — Misfire Detected
    P0307 Cylinder #7 — Misfire Detected
    P0308 Cylinder #8 — Misfire Detected
    P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
    P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
    P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
    P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
    P0325 Knock Sensor #1 — Circuit Malfunction (Bank #1 or Single Sensor)
    P0326 nock Sensor #1 — Circuit Range/Performance (Bank #1 or Single Sensor)
    P0327 Knock Sensor #1 — Circuit Low Input (Bank #1 or Single Sensor)
    P0328 Knock Sensor #1 — Circuit High Input (Bank #1 or Single Sensor)
    P0329 Knock Sensor #1 — Circuit Input Intermittent (Bank #1 or Single Sensor)
    P0330 Knock Sensor #2 — Circuit Malfunction (Bank #2)
    P0331 Knock Sensor #2 — Circuit Range/Performance (Bank #2)
    P0332 Knock Sensor #2 — Circuit Low Input (Bank #2)
    P0333 Knock Sensor #2 — Circuit High Input (Bank #2)
    P0334 Knock Sensor #2 — Circuit Input Intermittent (Bank #2)
    P0335 Crankshaft Position Sensor "A" Circuit Malfunction
    P0336 Crankshaft Position Sensor "A" Circuit Range/Performance
    P0337 Crankshaft Position Sensor "A" Circuit Low Input
    P0338 Crankshaft Position Sensor "A" Circuit High Input
    P0339 Crankshaft Position Sensor "A" Circuit Intermittent
    P0340 Camshaft Position Sensor Circuit Malfunction
    P0341 Camshaft Position Sensor Circuit Range/Performance
    P0342 Camshaft Position Sensor Circuit Low Input
    P0343 Camshaft Position Sensor Circuit High Input
    P0344 Camshaft Position Sensor Circuit Intermittent
    P0350 Ignition Coil Primary/Secondary Circuit Malfunction
    P0351 Ignition Coil "A" Primary/Secondary Circuit Malfunction
    P0352 Ignition Coil "B" Primary/Secondary Circuit Malfunction
    P0353 Ignition Coil "C" Primary/Secondary Circuit Malfunction
    P0354 Ignition Coil "D" Primary/Secondary Circuit Malfunction
    P0355 Ignition Coil "E" Primary/Secondary Circuit Malfunction
    P0356 Ignition Coil "F" Primary/Secondary Circuit Malfunction
    P0357 Ignition Coil "G" Primary/Secondary Circuit Malfunction
    P0358 Ignition Coil "H" Primary/Secondary Circuit Malfunction
    P0359 Ignition Coil "I" Primary/Secondary Circuit Malfunction
    P0360 Ignition Coil "J" Primary/Secondary Circuit Malfunction
    P0361 Ignition Coil "K" Primary/Secondary Circuit Malfunction
    P0362 Ignition Coil "L" Primary/Secondary Circuit Malfunction
    P0370 Timing Reference High Resolution Signal "A" Malfunction
    P0371 Timing Reference High Resolution Signal "A" Too Many Pulses
    P0372 Timing Reference High Resolution Signal "A" Too Few Pulses
    P0373 Timing Reference High Resolution Signal "A" Intermittent/Erratic Pulses
    P0374 Timing Reference High Resolution Signal "A" No Pulses
    P0375 Timing Reference High Resolution Signal "B" Malfunction
    P0376 Timing Reference High Resolution Signal "B" Too Many Pulses
    P0377 Timing Reference High Resolution Signal "B" Too Few Pulses
    P0378 Timing Reference High Resolution Signal "B" Intermittent/Erratic Pulses
    P0379 Timing Reference High Resolution Signal "B" No Pulses
    P0380 Glow Plug/Heater Circuit "A" Malfunction
    P0381 Glow Plug/Heater Indicator Circuit Malfunction
    P0382 Glow Plug/Heater Circuit "B" Malfunction
    P0385 Crankshaft Position Sensor "B" Circuit Malfunction
    P0386 Crankshaft Position Sensor "B" Circuit Range/Performance
    P0387 Crankshaft Position Sensor "B" Circuit Low Input
    P0388 Crankshaft Position Sensor "B" Circuit High Input
    P0389 Crankshaft Position Sensor "B" Circuit Intermittent
    P0400 Exhaust Gas Recirculation Flow Malfunction
    P0401 Exhaust Gas Recirculation Flow Insufficient Detected
    P0402 Exhaust Gas Recirculation Flow Excessive Detected
    P0403 Exhaust Gas Recirculation Circuit Malfunction
    P0404 Exhaust Gas Recirculation Circuit Range/Performance
    P0405 Exhaust Gas Recirculation Sensor "A" Circuit Low
    P0406 Exhaust Gas Recirculation Sensor "A" Circuit High
    P0407 Exhaust Gas Recirculation Sensor "B" Circuit Low
    P0408 Exhaust Gas Recirculation Sensor "B" Circuit High
    P0410 Secondary Air Injection System Malfunction
    P0411 Secondary Air Injection System Incorrect Flow Detected
    P0412 Secondary Air Injection System Switching Valve "A" Circuit Malfunction
    P0413 Secondary Air Injection System Switching Valve "A" Circuit Open
    P0414 Secondary Air Injection System Switching Valve "A" Circuit Shorted
    P0415 Secondary Air Injection System Switching Valve "B" Circuit Malfunction
    P0416 Secondary Air Injection System Switching Valve "B" Circuit Open
    P0417 Secondary Air Injection System Switching Valve "B" Circuit Shorted
    P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
    P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
    P0420 Catalyst System Efficiency Below Threshold (Bank #1)
    P0421 Warm Up Catalyst Efficiency Below Threshold (Bank #1)
    P0422 Main Catalyst Efficiency Below Threshold (Bank #1)
    P0423 Heated Catalyst Efficiency Below Threshold (Bank #1)
    P0424 Heated Catalyst Temperature Below Threshold (Bank #1)
    P0430 Catalyst System Efficiency Below Threshold (Bank #2)
    P0431 Warm Up Catalyst Efficiency Below Threshold (Bank #2)
    P0432 Main Catalyst Efficiency Below Threshold (Bank #2)
    P0433 Heated Catalyst Efficiency Below Threshold (Bank #2)
    P0434 Heated Catalyst Temperature Below Threshold (Bank #2)
    P0440 Evaporative Emission Control System Malfunction
    P0441 Evaporative Emission Control System Incorrect Purge Flow
    P0442 Evaporative Emission Control System Leak Detected (Small Leak)
    P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
    P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
    P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
    P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
    P0447 Evaporative Emission Control System Vent Control Circuit Open
    P0448 Evaporative Emission Control System Vent Control Circuit Shorted
    P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
    P0450 Evaporative Emission Control System Pressure Sensor Malfunction
    P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
    P0452 Evaporative Emission Control System Pressure Sensor Low Input
    P0453 Evaporative Emission Control System Pressure Sensor High Input
    P0454 Evaporative Emission Control System Pressure Sensor Intermittent
    P0455 Evaporative Emission Control System Leak Detected (Gross Leak)
    P0460 Fuel Level Sensor Circuit Malfunction
    P0461 Fuel Level Sensor Circuit Range/Performance
    P0462 Fuel Level Sensor Circuit Low Input
    P0463 Fuel Level Sensor Circuit High Input
    P0464 Fuel Level Sensor Circuit Intermittent
    P0465 Purge Flow Sensor Circuit Malfunction
    P0466 Purge Flow Sensor Circuit Range/Performance
    P0467 Purge Flow Sensor Circuit Low Input
    P0468 Purge Flow Sensor Circuit High Input
    P0469 Purge Flow Sensor Circuit Intermittent
    P0470 Exhaust Pressure Sensor Malfunction
    P0471 Exhaust Pressure Sensor Range/Performance
    P0472 Exhaust Pressure Sensor Low
    P0473 Exhaust Pressure Sensor High
    P0474 Exhaust Pressure Sensor Intermittent
    P0475 Exhaust Pressure Control Valve Malfunction
    P0476 Exhaust Pressure Control Valve Range/Performance
    P0477 Exhaust Pressure Control Valve Low
    P0478 Exhaust Pressure Control Valve High
    P0479 Exhaust Pressure Control Valve Intermittent
    P0480 Cooling Fan #1 Control Circuit Malfunction
    P0481 Cooling Fan #2 Control Circuit Malfunction
    P0482 Cooling Fan #3 Control Circuit Malfunction
    P0483 Cooling Fan Rationality Check Malfunction
    P0484 Cooling Fan Circuit Over Current
    P0485 Cooling Fan Power/Ground Circuit Malfunction
    P0500 Vehicle Speed Sensor Malfunction
    P0501 Vehicle Speed Sensor Range/Performance
    P0502 Vehicle Speed Sensor Circuit Low Input
    P0503 Vehicle Speed Sensor Intermittent/Erratic/High
    P0505 Idle Control System Malfunction
    P0506 Idle Control System RPM Lower Than Expected
    P0507 Idle Control System RPM Higher Than Expected
    P0510 Closed Throttle Position Switch Malfunction
    P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
    P0521 Engine Oil Pressure Sensor/Switch Range/Performance
    P0522 Engine Oil Pressure Sensor/Switch Low Voltage
    P0523 Engine Oil Pressure Sensor/Switch High Voltage
    P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
    P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
    P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
    P0533 A/C Refrigerant Pressure Sensor Circuit High Input
    P0534 A/C Refrigerant Charge Loss
    P0550 Power Steering Pressure Sensor Circuit Malfunction
    P0551 Power Steering Pressure Sensor Circuit Range/Performance
    P0552 Power Steering Pressure Sensor Circuit Low Input
    P0553 Power Steering Pressure Sensor Circuit High Input
    P0554 Power Steering Pressure Sensor Circuit Intermittent
    P0560 System Voltage Malfunction
    P0561 System Voltage Unstable
    P0562 System Voltage Low
    P0563 System Voltage High
    P0565 Cruise Control On Signal Malfunction
    P0566 Cruise Control Off Signal Malfunction
    P0567 Cruise Control Resume Signal Malfunction
    P0568 Cruise Control Set Signal Malfunction
    P0569 Cruise Control Coast Signal Malfunction
    P0570 Cruise Control Accel Signal Malfunction
    P0571 Cruise Control/Brake Switch "A" Circuit Malfunction
    P0572 Cruise Control/Brake Switch "A" Circuit Low
    P0573 Cruise Control/Brake Switch "A" Circuit High
    P0574 Through P0580 Reserved for Cruise Codes
    P0600 Serial Communication Link Malfunction
    P0601 Internal Control Module Memory Check Sum Error
    P0602 Control Module Programming Error
    P0603 Internal Control Module Keep Alive Memory (KAM) Error
    P0604 Internal Control Module Random Access Memory (RAM) Error
    P0605 Internal Control Module Read Only Memory (ROM) Error
    P0606 PCM Processor Fault
    P0608 Control Module VSS Output "A" Malfunction
    P0609 Control Module VSS Output "B" Malfunction
    P0620 Generator Control Circuit Malfunction
    P0621 Generator Lamp "L" Control Circuit Malfunction
    P0622 Generator Field "F" Control Circuit Malfunction
    P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
    P0654 Engine RPM Output Circuit Malfunction
    P0655 Engine Hot Lamp Output Control Circuit Malfunction
    P0656 Fuel Level Output Circuit Malfunction
    P0700 Transmission Control System Malfunction
    P0701 Transmission Control System Range/Performance
    P0702 Transmission Control System Electrical
    P0703 Torque Converter/Brake Switch "B" Circuit Malfunction
    P0704 Clutch Switch Input Circuit Malfunction
    P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input)
    P0706 Transmission Range Sensor Circuit Range/Performance
    P0707 Transmission Range Sensor Circuit Low Input
    P0708 Transmission Range Sensor Circuit High Input
    P0709 Transmission Range Sensor Circuit Intermittent
    P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
    P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
    P0712 Transmission Fluid Temperature Sensor Circuit Low Input
    P0713 Transmission Fluid Temperature Sensor Circuit High Input
    P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
    P0715 Input/Turbine Speed Sensor Circuit Malfunction
    P0716 Input/Turbine Speed Sensor Circuit Range/Performance
    P0717 Input/Turbine Speed Sensor Circuit No Signal
    P0718 Input/Turbine Speed Sensor Circuit Intermittent
    P0719 Torque Converter/Brake Switch "B" Circuit Low
    P0720 Output Speed Sensor Circuit Malfunction
    P0721 Output Speed Sensor Circuit Range/Performance
    P0722 Output Speed Sensor Circuit No Signal
    P0723 Output Speed Sensor Circuit Intermittent
    P0724 Torque Converter/Brake Switch "B" Circuit High
    P0725 Engine Speed Input Circuit Malfunction
    P0726 Engine Speed Input Circuit Range/Performance
    P0727 Engine Speed Input Circuit No Signal
    P0728 Engine Speed Input Circuit Intermittent
    P0730 Incorrect Gear Ratio
    P0731 Gear #1 Incorrect Ratio
    P0732 Gear #2 Incorrect Ratio
    P0733 Gear #3 Incorrect Ratio
    P0734 Gear #4 Incorrect Ratio
    P0735 Gear #5 Incorrect Ratio
    P0736 Reverse Incorrect Ratio
    P0740 Torque Converter Clutch Circuit Malfunction
    P0741 Torque Converter Clutch Circuit Performance or Stuck Off
    P0742 Torque Converter Clutch Circuit Stuck On
    P0743 Torque Converter Clutch Circuit Electrical
    P0744 Torque Converter Clutch Circuit Intermittent
    P0745 Pressure Control Solenoid Malfunction
    P0746 Pressure Control Solenoid Performance or Stuck Off
    P0747 Pressure Control Solenoid Stuck On
    P0748 Pressure Control Solenoid Electrical
    P0749 Pressure Control Solenoid Intermittent
    P0750 Shift Solenoid "A" Malfunction
    P0751 Shift Solenoid "A" Performance or Stuck Off
    P0752 Shift Solenoid "A" Stuck On
    P0753 Shift Solenoid "A" Electrical
    P0754 Shift Solenoid "A" Intermittent
    P0755 Shift Solenoid "B" Malfunction
    P0756 Shift Solenoid "B" Performance or Stuck Off
    P0757 Shift Solenoid "B" Stuck On
    P0758 Shift Solenoid "B" Electrical
    P0759 Shift Solenoid "B" Intermittent
    P0760 Shift Solenoid "C" Malfunction
    P0761 Shift Solenoid "C" Performance Or Stuck Off
    P0762 Shift Solenoid "C" Stuck On
    P0763 Shift Solenoid "C" Electrical
    P0764 Shift Solenoid "C" Intermittent
    P0765 Shift Solenoid "D" Malfunction
    P0766 Shift Solenoid "D" Performance Or Stuck Off
    P0767 Shift Solenoid "D" Stuck On
    P0768 Shift Solenoid "D" Electrical
    P0769 Shift Solenoid "D" Intermittent
    P0770 Shift Solenoid "E" Malfunction
    P0771 Shift Solenoid "E" Performance Or Stuck Off
    P0772 Shift Solenoid "E" Stuck On
    P0773 Shift Solenoid "E" Electrical
    P0774 Shift Solenoid "E" Intermittent
    P0780 Shift Malfunction
    P0781 1–2 Shift Malfunction
    P0782 2–3 Shift Malfunction
    P0783 3–4 Shift Malfunction
    P0784 4–5 Shift Malfunction
    P0785 Shift/Timing Solenoid Malfunction
    P0786 Shift/Timing Solenoid Range/Performance
    P0787 Shift/Timing Solenoid Low
    P0788 Shift/Timing Solenoid High
    P0789 Shift/Timing Solenoid Intermittent
    P0790 Normal/Performance Switch Circuit Malfunction
    P0801 Reverse Inhibit Control Circuit Malfunction
    P0803 1–4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
    P0804 1–4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
    P1100 Barometric Pressure Sensor Circuit Fault
    P1120 Accelerator Pedal Position Sensor Circuit Malfunction
    P1121 Accelerator Pedal Position Sensor Range/Performance Problem
    P1125 Throttle Control Motor Circuit Malfunction
    P1126 Magnetic Clutch Circuit Malfunction
    P1127 ETCS Actuator Power Source Circuit Malfunction
    P1128 Throttle Control Motor Lock Malfunction
    P1129 Electric Throttle Control System Malfunction
    P1130 A/F Sensor Circuit Range / Performance Malfunction (Bank #1 Sensor #1)
    P1133 A/F Sensor Circuit Response Malfunction (Bank #1 Sensor #1)
    P1135 A/F Sensor Heater Circuit Malfunction (Bank #1 Sensor #1)
    P1150 A/F Sensor Circuit Range / Performance Malfunction (Bank #2 Sensor #1)
    P1153 A/F Sensor Circuit Response Malfunction (Bank #2 Sensor #1)
    P1155 A/F Sensor Heater Circuit Malfunction (Bank #2 Sensor #1)
    P1200 Fuel Pump Relay Circuit Fault
    P1300 Igniter Circuit Fault (Bank #1)
    P1305 Igniter Circuit Fault (Bank #2)
    P1310 Igniter Circuit Fault (Bank #3)
    P1315 Igniter Circuit Fault (Bank #4)
    P1320 Igniter Circuit Fault (Bank #5)
    P1325 Igniter Circuit Fault (Bank #6)
    P1330 Igniter Circuit Fault (Bank #7)
    P1335 Crankshaft Position Sensor Circuit Fault (during engine running)
    P1340 Igniter Circuit Fault (Bank #8)
    P1400 Sub-Throttle Position Sensor Circuit Fault
    P1401 Sub-Throttle Position Sensor Performance
    P1500 Starter Signal Circuit Fault
    P1510 Air Volume Too Low With Supercharger On
    P1520 Stop Light Switch Signal Malfunction
    P1600 ECM Battery Back-up Circuit Fault
    P1633 ECM Malfunction (ETCS Circuit)
    P1605 Knock Control CPU Fault
    P1700 Vehicle Speed Sensor Circuit Fault
    P1705 Direct Clutch Speed Sensor Circuit Fault
    P1765 Linear Shift Solenoid Circuit Fault
    P1780 Park Neutral Position Switch Fault
    Dura Lex sed Lex
    Feb 2001
    Leiria
    Default Re: Códigos de avaria OBDII Toyota Corolla
    GENERIC OBD II CODE DEFINITIONS
    P0010 "A" Camshaft Position Actuator Circuit (Bank 1)
    P0011 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
    P0012 "A" Camshaft Position - Timing Over-Retarded (Bank 1)
    P0013 "B" Camshaft Position - Actuator Circuit (Bank 1)
    P0014 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
    P0015 "B" Camshaft Position - Timing Over-Retarded (Bank 1)
    P0020 "A" Camshaft Position Actuator Circuit (Bank 2)
    P0021 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
    P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
    P0023 "B" Camshaft Position - Actuator Circuit (Bank 2)
    P0024 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
    P0025 "B" Camshaft Position - Timing Over-Retarded (Bank 2)
    P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
    P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
    P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
    P0033 Turbo Charger Bypass Valve Control Circuit
    P0034 Turbo Charger Bypass Valve Control Circuit Low
    P0035 Turbo Charger Bypass Valve Control Circuit High
    P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
    P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
    P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
    P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
    P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
    P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
    P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
    P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
    P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
    P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
    P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
    P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
    P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
    P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
    P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
    P0065 Air Assisted Injector Control Range/Performance
    P0066 Air Assisted Injector Control Circuit or Circuit Low
    P0067 Air Assisted Injector Control Circuit High
    P0070 Ambient Air Temperature Sensor Circuit
    P0071 Ambient Air Temperature Sensor Range/Performance
    P0072 Ambient Air Temperature Sensor Circuit Low Input
    P0073 Ambient Air Temperature Sensor Circuit High Input
    P0074 Ambient Air Temperature Sensor Circuit Intermittent
    P0075 Intake Valve Control Solenoid Circuit (Bank 1)
    P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
    P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
    P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
    P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
    P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
    P0081 Intake Valve Control Solenoid Circuit (Bank 2)
    P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
    P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
    P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
    P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
    P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
    P0101 Mass or Volume Circuit Range/Performance Problem
    P0102 Mass or Volume Circuit Low Input
    P0103 Mass or Volume Circuit High Input
    P0104 Mass or Volume Circuit Intermittent
    P0120 Throttle/Pedal Position Sensor/Switch A Circuit Malfunction
    P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
    P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input
    P0123 Throttle/Pedal Position Sensor/Switch A Circuit High Input
    P0124 Throttle/Pedal Position Sensor/Switch A Circuit Intermittent
    P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
    P0126 Insufficient Coolant Temperature for Stable Operation
    P0127 Intake Air Temperature Too High
    P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
    P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
    P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
    P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
    P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
    P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
    P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
    P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
    P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
    P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
    P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
    P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
    P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
    P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
    P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
    P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
    P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
    P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
    P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
    P0148 Fuel Delivery Error
    P0149 Fuel Timing Error
    P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
    P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
    P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
    P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
    P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
    P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
    P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
    P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
    P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
    P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
    P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
    P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
    P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
    P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
    P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
    P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
    P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
    P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
    P0168 Fuel Temperature Too High
    P0169 Incorrect Fuel Composition
    P0170 Fuel Trim Malfunction (Bank 1)
    P0171 System too Lean (Bank 1)
    P0172 System too Rich (Bank 1)
    P0173 Fuel Trim Malfunction (Bank 2)
    P0174 System too Lean (Bank 2)
    P0175 System too Rich (Bank 2)
    P0180 Fuel Temperature Sensor A Circuit Malfunction
    P0181 Fuel Temperature Sensor A Circuit Range/Performance
    P0182 Fuel Temperature Sensor A Circuit Low Input
    P0183 Fuel Temperature Sensor A Circuit High Input
    P0184 Fuel Temperature Sensor A Circuit Intermittent
    P0185 Fuel Temperature Sensor B Circuit Malfunction
    P0186 Fuel Temperature Sensor B Circuit Range/Performance
    P0187 Fuel Temperature Sensor B Circuit Low Input
    P0188 Fuel Temperature Sensor B Circuit High Input
    P0189 Fuel Temperature Sensor B Circuit Intermittent
    P0201 Injector Circuit Malfunction - Cylinder 1
    P0202 Injector Circuit Malfunction - Cylinder 2
    P0203 Injector Circuit Malfunction - Cylinder 3
    P0204 Injector Circuit Malfunction - Cylinder 4
    P0205 Injector Circuit Malfunction - Cylinder 5
    P0206 Injector Circuit Malfunction - Cylinder 6
    P0207 Injector Circuit Malfunction - Cylinder 7
    P0208 Injector Circuit Malfunction - Cylinder 8
    P0209 Injector Circuit Malfunction - Cylinder 9
    P0210 Injector Circuit Malfunction - Cylinder 10
    P0211 Injector Circuit Malfunction - Cylinder 11
    P0212 Injector Circuit Malfunction - Cylinder 12
    P0213 Cold Start Injector 1 Malfunction
    P0214 Cold Start Injector 2 Malfunction
    P0217 Engine Overtemp Condition
    P0219 Engine Overspeed Condition
    P0220 Throttle/Pedal Position Sensor/Switch B Circuit Malfunction
    P0221 Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance Problem
    P0222 Throttle/Pedal Position Sensor/Switch B Circuit Low Input
    P0223 Throttle/Pedal Position Sensor/Switch B Circuit High Input
    P0224 Throttle/Pedal Position Sensor/Switch B Circuit Intermittent
    P0225 Throttle/Pedal Position Sensor/Switch C Circuit Malfunction
    P0226 Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance Problem
    P0227 Throttle/Pedal Position Sensor/Switch C Circuit Low Input
    P0228 Throttle/Pedal Position Sensor/Switch C Circuit High Input
    P0229 Throttle/Pedal Position Sensor/Switch C Circuit Intermittent
    P0234 Engine Overboost Condition
    P0235 Turbocharger Boost Sensor A Circuit Malfunction
    P0236 Turbocharger Boost Sensor A Circuit Range/Performance
    P0237 Turbocharger Boost Sensor A Circuit Low
    P0238 Turbocharger Boost Sensor A Circuit High
    P0239 Turbocharger Boost Sensor B Circuit Malfunction
    P0240 Turbocharger Boost Sensor B Circuit Range/Performance
    P0241 Turbocharger Boost Sensor B Circuit Low
    P0242 Turbocharger Boost Sensor B Circuit High
    P0243 Turbocharger Wastegate Solenoid A Malfunction
    P0244 Turbocharger Wastegate Solenoid A Range/Performance
    P0245 Turbocharger Wastegate Solenoid A Low
    P0246 Turbocharger Wastegate Solenoid A High
    P0247 Turbocharger Wastegate Solenoid B Malfunction
    P0248 Turbocharger Wastegate Solenoid B Range/Performance
    P0249 Turbocharger Wastegate Solenoid B Low
    P0250 Turbocharger Wastegate Solenoid B High
    P0251 Injection Pump A Rotor/Cam Malfunction
    P0252 Injection Pump A Rotor/Cam Range/Performance
    P0253 Injection Pump A Rotor/Cam Low
    P0254 Injection Pump A Rotor/Cam High
    P0255 Injection Pump A Rotor/Cam Intermitted
    P0256 Injection Pump B Rotor/Cam Malfunction
    P0257 Injection Pump B Rotor/Cam Range/Performance
    P0258 Injection Pump B Rotor/Cam Low
    P0259 Injection Pump B Rotor/Cam High
    P0260 Injection Pump B Rotor/Cam Intermitted
    P0261 Cylinder 1 Injector Circuit Low
    P0262 Cylinder 1 Injector Circuit High
    P0263 Cylinder 1 Contribution/Balance Fault
    P0264 Cylinder 2 Injector Circuit Low
    P0265 Cylinder 2 Injector Circuit High
    P0266 Cylinder 2 Contribution/Balance Fault
    P0267 Cylinder 3 Injector Circuit Low
    P0268 Cylinder 3 Injector Circuit High
    P0269 Cylinder 3 Contribution/Balance Fault
    P0270 Cylinder 4 Injector Circuit Low
    P0271 Cylinder 4 Injector Circuit High
    P0272 Cylinder 4 Contribution/Balance Fault
    P0273 Cylinder 5 Injector Circuit Low
    P0274 Cylinder 5 Injector Circuit High
    P0275 Cylinder 5 Contribution/Balance Fault
    P0276 Cylinder 6 Injector Circuit Low
    P0277 Cylinder 6 Injector Circuit High
    P0278 Cylinder 6 Contribution/Balance Fault
    P0279 Cylinder 7 Injector Circuit Low
    P0280 Cylinder 7 Injector Circuit High
    P0281 Cylinder 7 Contribution/Balance Fault
    P0282 Cylinder 8 Injector Circuit Low
    P0283 Cylinder 8 Injector Circuit High
    P0284 Cylinder 8 Contribution/Balance Fault
    P0285 Cylinder 9 Injector Circuit Low
    P0286 Cylinder 9 Injector Circuit High
    P0287 Cylinder 9 Contribution/Balance Fault
    P0288 Cylinder 10 Injector Circuit Low
    P0289 Cylinder 10 Injector Circuit High
    P0290 Cylinder 10 Contribution/Balance Fault
    P0291 Cylinder 11 Injector Circuit Low
    P0292 Cylinder 11 Injector Circuit High
    P0293 Cylinder 11 Contribution/Balance Fault
    P0294 Cylinder 12 Injector Circuit Low
    P0295 Cylinder 12 Injector Circuit High
    P0296 Cylinder 12 Contribution/Balance Fault
    P0298 Engine Oil Over Temperature
    P0301 Cylinder 1 Misfire Detected
    P0302 Cylinder 2 Misfire Detected
    P0303 Cylinder 3 Misfire Detected
    P0304 Cylinder 4 Misfire Detected
    P0305 Cylinder 5 Misfire Detected
    P0306 Cylinder 6 Misfire Detected
    P0307 Cylinder 7 Misfire Detected
    P0308 Cylinder 8 Misfire Detected
    P0309 Cylinder 9 Misfire Detected
    P0310 Cylinder 10 Misfire Detected
    P0311 Cylinder 11 Misfire Detected
    P0312 Cylinder 12 Misfire Detected
    P0313 Misfire Detected with Low Fuel
    P0314 Single Cylinder Misfire (Cylinder not specified)
    P0324 Knock Control System Error
    P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
    P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
    P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
    P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
    P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
    P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
    P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
    P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
    P0333 Knock Sensor 2 Circuit High Input (Bank 2)
    P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
    P0335 Crankshaft Position Sensor A Circuit Malfunction
    P0336 Crankshaft Position Sensor A Circuit Range/Performance
    P0337 Crankshaft Position Sensor A Circuit Low Input
    P0338 Crankshaft Position Sensor A Circuit High Input
    P0339 Crankshaft Position Sensor A Circuit Intermittent
    P0345 Camshaft Position Sensor "A" Circuit (Bank 2)
    P0346 Camshaft Position Sensor "A" Circuit Range/Performance (Bank 2)
    P0347 Camshaft Position Sensor "A" Circuit Low Input (Bank 2)
    P0348 Camshaft Position Sensor "A" Circuit High Input (Bank 2)
    P0349 Camshaft Position Sensor "A" Circuit Intermittent (Bank 2)
    P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
    P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
    P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
    P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
    P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
    P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
    P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
    P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
    P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
    P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
    P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
    P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
    P0365 Camshaft Position Sensor "B" Circuit (Bank 1)
    P0366 Camshaft Position Sensor "B" Circuit Range/Performance (Bank 1)
    P0367 Camshaft Position Sensor "B" Circuit Low Input (Bank 1)
    P0368 Camshaft Position Sensor "B" Circuit High Input (Bank 1)
    P0369 Camshaft Position Sensor "B" Circuit Intermittent (Bank 1)
    P0370 Timing Reference High Resolution Signal A Malfunction
    P0371 Timing Reference High Resolution Signal A Too Many Pulses
    P0372 Timing Reference High Resolution Signal A Too Few Pulses
    P0373 Timing Reference High Resolution Signal A Intermittent/ Erratic Pulses
    P0374 Timing Reference High Resolution Signal A No Pulses
    P0375 Timing Reference High Resolution Signal B Malfunction
    P0376 Timing Reference High Resolution Signal B Too Many Pulses
    P0377 Timing Reference High Resolution Signal B Too Few Pulses
    P0378 Timing Reference High Resolution Signal B Intermittent/ Erratic Pulses
    P0379 Timing Reference High Resolution Signal B No Pulses
    P0380 Glow Plug/Heater Circuit Malfunction
    P0385 Crankshaft Position Sensor B Circuit Malfunction
    P0386 Crankshaft Position Sensor B Circuit Range/Performance
    P0387 Crankshaft Position Sensor B Circuit Low Input
    P0388 Crankshaft Position Sensor B Circuit High Input
    P0389 Crankshaft Position Sensor B Circuit Intermittent
    P0390 Camshaft Position Sensor "B" Circuit (Bank 2)
    P0391 Camshaft Position Sensor "B" Circuit Range/Performance (Bank 2)
    P0392 Camshaft Position Sensor "B" Circuit Low Input (Bank 2)
    P0393 Camshaft Position Sensor "B" Circuit High Input (Bank 2)
    P0394 Camshaft Position Sensor "B" Circuit Intermittent (Bank 2)
    P0405 Exhaust Gas Recirculation Sensor A Circuit Low
    P0406 Exhaust Gas Recirculation Sensor A Circuit High
    P0407 Exhaust Gas Recirculation Sensor B Circuit Low
    P0408 Exhaust Gas Recirculation Sensor B Circuit High
    P0409 Exhaust Gas Recirculation Sensor "A" Circuit
    P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
    P0413 Secondary Air Injection System Switching Valve A Circuit Open
    P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
    P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
    P0416 Secondary Air Injection System Switching Valve B Circuit Open
    P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
    P0420 Catalyst System Efficiency Below Threshold (Bank 1)
    P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
    P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
    P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
    P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
    P0425 Catalyst Temperature Sensor (Bank 1)
    P0426 Catalyst Temperature Sensor Range/Performance (Bank 1)
    P0427 Catalyst Temperature Sensor Low Input (Bank 1)
    P0428 Catalyst Temperature Sensor High Input (Bank 1)
    P0429 Catalyst Heater Control Circuit (Bank 1)
    P0430 Catalyst System Efficiency Below Threshold (Bank 2)
    P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
    P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
    P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
    P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
    P0435 Catalyst Temperature Sensor (Bank 2)
    P0436 Catalyst Temperature Sensor Range/Performance (Bank 2)
    P0437 Catalyst Temperature Sensor Low Input (Bank 2)
    P0438 Catalyst Temperature Sensor High Input (Bank 2)
    P0439 Catalyst Heater Control Circuit (Bank 2)
    P0442 Evaporative Emission Control System Leak Detected (small leak)
    P0455 Evaporative Emission Control System Leak Detected (gross leak)
    P0456 Evaporative Emission Control System Leak Detected (very small leak)
    P0457 Evaporative Emission Control System Leak Detected (fuel cap loose/off)
    P0480 Cooling Fan 1 Control Circuit Malfunction
    P0481 Cooling Fan 2 Control Circuit Malfunction
    P0482 Cooling Fan 3 Control Circuit Malfunction
    P0486 Exhaust Gas Recirculation Sensor "B" Circuit
    P0487 Exhaust Gas Recirculation Throttle Position Control Circuit
    P0488 Exhaust Gas Recirculation Throttle Position Control Range/Performance
    P0491 Secondary Air Injection System (Bank 1)
    P0492 Secondary Air Injection System (Bank 2)
    P0508 Idle Control System Circuit Low
    P0509 Idle Control System Circuit High
    P0512 Starter Request Circuit
    P0513 Incorrect Immobilizer Key ("Immobilizer" pending SAE J1930 approval)
    P0515 Battery Temperature Sensor Circuit
    P0516 Battery Temperature Sensor Circuit Low
    P0517 Battery Temperature Sensor Circuit High
    P0520 Engine Oil Pressure/Switch Circuit Malfunction
    P0521 Engine Oil Pressure/Switch Range/Performance
    P0522 Engine Oil Pressure/Switch Low Voltage
    P0523 Engine Oil Pressure/Switch High Voltage
    P0524 Engine Oil Pressure Too Low
    P0534 Air Conditioner Refrigerant Charge Loss
    P0540 Intake Air Heater Circuit
    P0541 Intake Air Heater Circuit Low
    P0542 Intake Air Heater Circuit High
    P0544 Exhaust Gas Temperature Sensor Circuit (Bank 1)
    P0545 Exhaust Gas Temperature Sensor Circuit Low (Bank 1)
    P0546 Exhaust Gas Temperature Sensor Circuit High (Bank 1)
    P0547 Exhaust Gas Temperature Sensor Circuit (Bank 2)
    P0548 Exhaust Gas Temperature Sensor Circuit Low (Bank 2)
    P0549 Exhaust Gas Temperature Sensor Circuit High (Bank 2)
    P0564 Cruise Control Multi-Function Input Signal
    P0571 Cruise Control/Brake Switch A Circuit Malfunction
    P0572 Cruise Control/Brake Switch A Circuit Low
    P0573 Cruise Control/Brake Switch A Circuit High
    P0574 Cruise Control System - Vehicle Speed Too High
    P0575 Cruise Control Input Circuit
    P0576 Cruise Control Input Circuit Low
    P0577 Cruise Control Input Circuit High
    P0578-P0580 Reserved for Cruise Control Codes
    P0607 Control Module Performance
    P0610 Control Module Vehicle Options Error
    P0615 Starter Relay Circuit
    P0616 Starter Relay Circuit Low
    P0617 Starter Relay Circuit High
    P0618 Alternative Fuel Control Module KAM Error
    P0619 Alternative Fuel Control Module RAM/ROM Error
    P0623 Generator Lamp Control Circuit
    P0624 Fuel Cap Lamp Control Circuit
    P0630 VIN Not Programmed or Mismatch - ECM/PCM
    P0631 VIN Not Programmed or Mismatch - TCM
    P0635 Power Steering Control Circuit
    P0636 Power Steering Control Circuit Low
    P0637 Power Steering Control Circuit High
    P0638 Throttle Actuator Control Range/Performance (Bank 1)
    P0639 Throttle Actuator Control Range/Performance (Bank 2)
    P0640 Intake Air Heater Control Circuit
    P0645 A/C Clutch Relay Control Circuit
    P0646 A/C Clutch Relay Control Circuit Low
    P0647 A/C Clutch Relay Control Circuit High
    P0648 Immobilizer Lamp Control Circuit ("Immobilizer" pending SAE J1930 approval)
    P0649 Speed Control Lamp Control Circuit
    P0660 Intake Manifold Tuning Valve Control Circuit (Bank 1)
    P0661 Intake Manifold Tuning Valve Control Circuit Low (Bank 1)
    P0662 Intake Manifold Tuning Valve Control Circuit High (Bank 1)
    P0663 Intake Manifold Tuning Valve Control Circuit (Bank 2)
    P0664 Intake Manifold Tuning Valve Control Circuit Low (Bank 2)
    P0665 Intake Manifold Tuning Valve Control Circuit High (Bank 2)
    P0703 Torque Converter/Brake Switch B Circuit Malfunction
    P0719 Torque Converter/Brake Switch B Circuit Low
    P0724 Torque Converter/Brake Switch B Circuit High
    P0731 Gear 1 Incorrect Ratio
    P0732 Gear 2 Incorrect Ratio
    P0733 Gear 3 Incorrect Ratio
    P0734 Gear 4 Incorrect Ratio
    P0735 Gear 5 Incorrect Ratio
    P0737 TCM Engine Speed Output Circuit
    P0738 TCM Engine Speed Output Circuit Low
    P0739 TCM Engine Speed Output Circuit High
    P0750 Shift Solenoid A Malfunction
    P0751 Shift Solenoid A Performance or Stuck Off
    P0752 Shift Solenoid A Stuck On
    P0753 Shift Solenoid A Electrical
    P0754 Shift Solenoid A Intermittent
    P0755 Shift Solenoid B Malfunction
    P0756 Shift Solenoid B Performance or Stuck Off
    P0757 Shift Solenoid B Stuck On
    P0758 Shift Solenoid B Electrical
    P0759 Shift Solenoid B Intermittent
    P0760 Shift Solenoid C Malfunction
    P0761 Shift Solenoid C Performance or Stuck Off
    P0762 Shift Solenoid C Stuck On
    P0763 Shift Solenoid C Electrical
    P0764 Shift Solenoid C Intermittent
    P0765 Shift Solenoid D Malfunction
    P0766 Shift Solenoid D Performance or Stuck Off
    P0767 Shift Solenoid D Stuck On
    P0768 Shift Solenoid D Electrical
    P0769 Shift Solenoid D Intermittent
    P0770 Shift Solenoid E Malfunction
    P0771 Shift Solenoid E Performance or Stuck Off
    P0772 Shift Solenoid E Stuck On
    P0773 Shift Solenoid E Electrical
    P0774 Shift Solenoid E Intermittent
    P0775 Pressure Control Solenoid "B"
    P0776 Pressure Control Solenoid "B" Performance or Stuck Off
    P0777 Pressure Control Solenoid "B" Stuck On
    P0778 Pressure Control Solenoid "B" Electrical
    P0779 Pressure Control Solenoid "B" Intermittent
    P0781 1-2 Shift Malfunction
    P0782 2-3 Shift Malfunction
    P0783 3-4 Shift Malfunction
    P0784 4-5 Shift Malfunction
    P0791 Intermediate Shaft Speed Sensor Circuit
    P0792 Intermediate Shaft Speed Sensor Circuit Range/Performance
    P0793 Intermediate Shaft Speed Sensor Circuit No Signal
    P0794 Intermediate Shaft Speed Sensor Circuit Intermittent
    P0795 Pressure Control Solenoid "C"
    P0796 Pressure Control Solenoid "C" Performance or Stuck Off
    P0797 Pressure Control Solenoid "C" Stuck On
    P0798 Pressure Control Solenoid "C" Electrical
    P0799 Pressure Control Solenoid "C" Intermittent
    P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
    P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
    P0805 Clutch Position Sensor Circuit
    P0806 Clutch Position Sensor Circuit Range/Performance
    P0807 Clutch Position Sensor Circuit Low
    P0808 Clutch Position Sensor Circuit High
    P0809 Clutch Position Sensor Circuit Intermittent
    P0810 Clutch Position Control Error
    P0811 Excessive Clutch Slippage
    P0812 Reverse Input Circuit
    P0813 Reverse Output Circuit
    P0814 Transmission Range Display Circuit
    P0815 Upshift Switch Circuit
    P0816 Downshift Switch Circuit
    P0817 Starter Disable Circuit
    P0818 Driveline Disconnect Switch Input Circuit
    P0820 Gear Lever X-Y Position Sensor Circuit
    P0821 Gear Lever X Position Circuit
    P0822 Gear Lever Y Position Circuit
    P0823 Gear Lever X Position Circuit Intermittent
    P0824 Gear Lever Y Position Circuit Intermittent
    P0825 Gear Lever Push-Pull Switch (Shift Anticipate)
    P0830 Clutch Pedal Switch "A" Circuit
    P0831 Clutch Pedal Switch "A" Circuit Low
    P0832 Clutch Pedal Switch "A" Circuit High
    P0833 Clutch Pedal Switch "B" Circuit
    P0834 Clutch Pedal Switch "B" Circuit Low
    P0835 Clutch Pedal Switch "B" Circuit High
    P0836 Four Wheel Drive (4WD) Switch Circuit
    P0837 Four Wheel Drive (4WD) Switch Circuit Range/Performance
    P0838 Four Wheel Drive (4WD) Switch Circuit Low
    P0839 Four Wheel Drive (4WD) Switch Circuit High
    P0840 Transmission Fluid Pressure Sensor/Switch "A" Circuit
    P0841 Transmission Fluid Pressure Sensor/Switch "A" Circuit Range/Performance
    P0842 Transmission Fluid Pressure Sensor/Switch "A" Circuit Low
    P0843 Transmission Fluid Pressure Sensor/Switch "A" Circuit High
    P0844 Transmission Fluid Pressure Sensor/Switch "A" Circuit Intermittent
    P0845 Transmission Fluid Pressure Sensor/Switch "B" Circuit
    P0846 Transmission Fluid Pressure Sensor/Switch "B" Circuit Range/Performance
    P0847 Transmission Fluid Pressure Sensor/Switch "B" Circuit Low
    P0848 Transmission Fluid Pressure Sensor/Switch "B" Circuit High
    P0849 Transmission Fluid Pressure Sensor/Switch "B" Circuit Intermittent
    TOYOTA-SPECIFIC OBD II CODE DEFINITIONS
    P1100 BARO Sensor Circuit malfunction
    P1130 Air-Fuel Sensor Circuit Range/Performance
    P1133 Air-Fuel Sensor Circuit Response Malfunction
    P1135 Air-Fuel Sensor Heater Circuit Response Malfunction
    P1150 A/F Sensor Circuit Range/Performance Malfunction
    P1153 A./F Sensor Circuit Response Malfunction
    P1200 Fuel Pump Relay Circuit Malfunction
    P1300 Igniter Circuit Malfunction No. 1
    P1305 Igniter Circuit Malfunction No. 2 (1998-2000 Land Cruiser, 2000 Celica & Tundra)
    P1310 Igniter Circuit Malfunction No. 2 (Except 1998-2000 Land Cruiser, 2000 Celica & Tundra)
    P1310 Igniter Circuit Malfunction No. 3 (1998-2000 Land Cruiser, 2000 Celica & Tundra)
    P1315 Igniter Circuit Malfunction No. 4 (1998-2000 Land Cruiser, 2000 Celica & Tundra)
    P1320 Igniter Circuit Malfunction No. 5 (1998-2000 Land Cruiser & 2000 Tundra)
    P1325 Igniter Circuit Malfunction No. 6 (1998-2000 Land Cruiser & 2000 Tundra)
    P1330 Igniter Circuit Malfunction No. 7 (1998-2000 Land Cruiser & 2000 Tundra)
    P1335 No CKP Sensor Signal Engine Running
    P1340 Igniter Circuit Malfunction No. 8 (1998-2000 Land Cruiser & 2000 Tundra)
    P1346 VVT Sensor /Camshaft Position Sensor Circuit Range/Performance Problem (Bank 1)
    P1349 VVT System Malfunction
    P1351 VVT Sensor /Camshaft Position Sensor Circuit Range/Performance Problem (Bank 2)
    P1400 Sub-Throttle Position Sensor Malfunction
    P1401 Sub-Throttle Position Sensor Range/Performance Problem
    P1405 Turbo Pressure Sensor Circuit Malfunction
    P1406 Turbo Pressure Sensor Range/Performance Problem
    P1410 EGR Valve Position Sensor Circuit Malfunction
    P1411 EGR Valve Position Sensor Circuit Ranger/Performance
    P1500 Starter Signal Circuit Malfunction
    P1510 Boost Pressure Control Circuit Malfunction
    P1511 Boost Pressure Low Malfunction
    P1512 Boost Pressure High Malfunction
    P1520 Stop Lamp Switch Signal Malfunction
    P1565 Cruise Control Main Switch Circuit Malfunction
    P1600 ECM BATT Malfunction
    P1605 Knock Control CPU Malfunction
    P1630 Traction Control System Malfunction
    P1633 ECM Malfunction ECTS Circuit
    P1645 Body ECU Malfunction
    P1652 IACV Control Circuit Malfunction
    P1656 OCV Circuit Malfunction
    P1658 Waste Gate Valve Control Circuit Malfunction
    P1661 EGR Circuit Malfunction
    P1662 EGR By-Pass Valve Control Circuit Malfunction
    P1690 OCV Circuit Malfunction
    P1692 OCV Open Malfunction
    P1693 OCV Closed Malfunction
    P1780 PNP Switch Malfunction
    TROUBLESHOOTING SOME COMMON CODES
    P0100
    Mass or volume sensor or circuit
    Possible Problems
    MAF may be disconnected, or a wiring connection may be bad. MAF sensor may be faulty.
    Reset the code and see if it comes back.
    Verify that the Mass Air Flow Sensor wiring is connected properly and that there are no broken /frayed wires.
    Unplug and reconnect the MAF wiring harness
    Check the voltage of the MAF sensor (refer to a repair manual for vehicle specific information)
    Replace the MAF sensor
    P0101
    Mass or volume Circuit Range/Performance Problem
    Possible Problems
    Mass Air Flow (MAF) sensor or circuit. The PCM detects that the actual MAF sensor frequency signal is not within a predetermined range of the calculated MAF value for more than 4.0 seconds.
    Inspect for the following conditions:
    An incorrectly routed harness--Inspect the harness of the MAF sensor in order to verify that it is not routed too close to the following components:
    - The secondary ignition wires or coils
    - Any solenoids
    - Any relays
    - Any motors
    A low minimum air rate through the sensor bore may cause this DTC to set at idle or during deceleration. Inspect for any vacuum leaks downstream of the MAF sensor.
    A wide open throttle (WOT) acceleration from a stop should cause the MAF sensor g/s display on the scan tool to increase rapidly. This increase should be from 6-12 g/s at idle to 230 g/s or more at the time of the 1-2 shift. If the increase is not observed, inspect for a restriction in the induction system or the exhaust system.
    The barometric pressure (BARO) that is used in order to calculate the predicted MAF value is initially based on the MAP sensor at key ON.
    When the engine is running the MAP sensor value is continually updated near WOT. A skewed MAP sensor will cause the calculated MAF value to be inaccurate. The value shown for the MAP sensor display varies with the altitude. With the ignition ON and the engine OFF, 103 kPa is the approximate value near sea level. This value will decrease by approximately 3 kPa for every 305 meters (1,000 feet) of altitude.
    A high resistance on the ground circuit of the MAP sensor can cause this DTC to set.
    Any loss of vacuum to the MAP sensor can cause this DTC to set.
    P0102
    Mass or volume Circuit Low Input
    Mass Air Flow (MAF) sensor or circuit. MAF circuit had lower than expected voltage (air flow).
    Possible Problems
    The MAF may be disconnected, or a wiring connection may be bad
    The MAF may be dirty or otherwise contaminated (if you use an oiled air filter such as a K&N air filter, some of the oil may have made it's way onto the MAF sensor).
    The MAF sensor may be faulty
    The vehicle computer may be faulty (very rare)
    reset the code and see if it comes back.
    Verify that the Mass Air Flow Sensor wiring is connected properly and that there are no broken / frayed wires.
    Inspect for any air leaks near the MAF sensor.
    Take the MAF out and clean it using a spray cleaner such as brake cleaner or electrical contact cleaner. Be gentle with the sensor.
    Replace the MAF sensor.
    P0103
    Mass or Volume Circuit High Input.
    Possible Problems
    Mass Air Flow High (MAF) sensor or circuit. MAF circuit had higher than expected voltage (air flow).
    The MAF sensor may be damaged
    P0104
    Possible Problems
    Mass Air Flow High (MAF) sensor or circuit. MAF is producing incorrect air flow readings.
    The mass air flow (MAF) circuit is incomplete (broken/frayed wire, etc.)
    There is an air leak in the intake system
    P0105
    The description of the expected voltages for the MAP sensor output (backprobing Terminal 2) in the Haynes manual is incorrect. The voltages listed are not the expected voltages, they are the voltage drops expected from the reference voltage.
    With the MAP connector attached and the ignition on and the vacuum line disconnected, measure the reference voltage by backprobing terminals 2 and 1. Measure the voltages at these same connectors while applying different vacuums at the port. If your reference voltage without vacuum is 3 volts (for example), then you should see the following voltages at these vacuums:
    3.94 in Hg 2.5-2.7 V [3.0 V (reference voltage) minus 0.5-0.3 V]
    7.87 in Hg 2.1-2.3 V (3.0 minus 0.9-0.7 V)
    11.81 in Hg 1.7-1.9 V (3.0 minus 1.3-1.1 V)
    15.75 in Hg 1.3-1.5 V (3.0 minus 1.7-1.5 V)
    19.69 in Hg 0.9-1.1 V (3.0 minus 2.1-1.9 V)
    Although your MAP may not exactly match what is listed above, the trend should be the same. I don't think there is anything magical about these absolute numbers, it is having a smooth trend that is important. There is bound to be some variation.
    P0123
    Possible Problems
    Computer has detected that the TPS (throttle position sensor) is reporting too high a voltage.
    Symptoms may include: Rough idle, High idle, Surging, or other symptoms may also be present
    TPS not mounted securely
    TPS circuit short to ground or another wire
    Faulty TPS
    Damaged computer (PCM)
    If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
    If engine is stumbling or hesitating, carefully inspect all wiring and connectors that lead to the TPS. More than likely the problem is with the TPS wiring.
    Check the voltage at the TPS (refer to a service manual for your vehicle for this specific information). If the voltage spikes or is too high (over 4.65 volts with key on, engine off), then that is indicative of a problem.
    Carefully trace each wire from the TPS wiring harness to check for breaks, rubbing against other components, etc.
    P0125
    Possible Problems
    After the engine is warmed up, oxygen sensor output does not indicated RICH even once when conditions warrant and continue for at least 1.5 min.
    Conditions: Engine speed 1,500 rpm or more, and speed 25-62 mph and throttle valve not completely closed.
    Open or short in HO2 sensor circuit or oxygen sensor
    or
    Engine coolant temperature (ECT) sensor indicates that the engine has not reached the required temperature level to enter closed-loop operation within a specified amount of time after starting the engine.
    Insufficient warm up time
    Low engine coolant level
    Leaking or stuck open thermostat
    Faulty coolant temperature sensor
    P0132
    Possible Problems
    Front oxygen sensor on the driver's side reading is too high.
    The oxygen sensor heater circuit is shorted out
    The wiring to the sensor is broken / frayed (less likely)
    Replace Front driver's side front oxygen sensor. <= Most likely
    Other possibilities
    Check for wiring problems (shorted, frayed wires)
    Check the voltage of the oxygen sensor
    P0133
    Possible Problems
    Front oxygen sensor on the driver's side voltage output is slower than 1 second rich to lean or lean to rich during idling after engine is warmed up (2 trip detection logic).
    Bad HO2 sensor<= Most likely
    Check and fix any exhaust leaks
    Check the frequency and amplitude of the oxygen sensor (advanced)
    Check for a deteriorating / contaminated oxygen sensor, replace if necessary
    Check for inlet air leaks
    Check the MAF sensor for proper operation
    See also P0125 above.
    P0139
    Possible Problems
    Rear oxygen sensor on the driver's side or the ECM does not adjust the air fuel ratio as expected to do so, or not adjusted as often as expected to do so once the engine is warmed or under normal engine use.
    Faulty oxygen sensor
    The wiring to the sensor is broken/frayed
    There is an exhaust leak
    Faulty HO2 Sensor 2 <= Most likely
    P0153
    Possible Problems
    Front oxygen sensor on the passenger's side voltage output is slower than 1 second rich to lean or lean to rich during idling after engine is warmed up (2 trip detection logic).
    P0159
    Possible Problems
    Rear oxygen sensor on the passenger side or the ECM is not adjusting the air fuel ratio as expected to do so, or not adjusted as often as expected to do so once the engine is warmed or under normal engine use.
    Wiring to the sensor is broken/frayed
    Exhaust leak
    Replace rear passenger side oxygen sensor.
    Check for a deteriorating/contaminated oxygen sensor, replace if necessary
    P0171
    Possible Problems
    When the air fuel ratio feedback is stable after engine warming up, the fuel trim is considerably in error on the LEAN side (2 trip detection logic)
    Air intake hose loose
    Fuel line pressure low (may be from running out of gas)
    Injector blockage
    HO2 sensor malfuction
    MAF meter malfunction
    Engine coolant temperature sensor malfunction
    Clean MAF meter with electronic circuit cleaner<= most likely
    Fix vacuum/intake leak downstream of MAF meter
    Inspect fuel lines for cracks, leaks, or pinches
    Replace fuel filter
    Check fuel pressure at the fuel rail
    Check output of HO2 sensor
    Check injector performance
    Check ECT sensor
    P0172
    Possible Problems
    When the air fuel ratio feedback is stable after engine warming up, the fuel trim is considerably in error on the RICH side (2 trip detection logic)
    Fuel line pressure high
    Injector leak
    Inspect all vacuum and PCV hoses, replace if necessary
    Check ECT sensor
    Check for adequate spark and ignition
    P0174
    See P0171 for Bank 1
    P0175
    See P0172 for Bank 1
    P0325
    No knock sensor 1 signal to ECM with engine speed 2,000 rpm or more.
    Possible Problems
    Open or short in knock sensor 1 circuit <= Most likely problem. Check sensor connector for good connection and check wire for damage. Wire is easily damaged when head is removed or similar repair work has been accomplished. Sensor can be tested with ohmmeter. There should be no continuity between the sensor terminal and the sensor body. Replace if there is continuity.
    Knock sensor 1 loosness - tighten sensor
    ECM
    P0330
    No knock sensor 2 signal to ECM with engine speed 2,000 rpm or more.
    Possible Problems
    Open or short in knock sensor 2 circuit <= Most likely problem.Check sensor connector for good connection and check wire for damage. Wire is easily damaged when head is removed or similar repair work has been accomplished. Sensor can be tested with ohmmeter. There should be no continuity between the sensor terminal and the sensor body. Replace if there is continuity.
    Knock sensor 2 loosness - tighten sensor
    ECM
    P0401
    After the engine is warmed up, the intake manifold absolute pressure is larger than the value calculated by the ECM while the EGR system is ON (2 trip detection logic).
    Possible Problems
    EGR valve stuck closed <= Most common Clean EGR valve
    EGR Vacuum Switching Valve (VSV)
    Open or short in VSV circuit for EGR
    EGR valve position sensor open or short circuit
    Vacuum or EGR hose disconnected
    Manifold absolute pressure sensor malfunction <=See P0105 above for testing MAP sensor
    ECM
    P0402
    After the engine is warmed up, conditions (a) and (b) continue.
    (a) The intake manifold absolute pressure is larger than the value calculated by the ECM while the EGR system is ON.
    (b) Misfiring is detected during idling (2 trip detection logic).
    Possible Problems
    EGR valve stuck open <= Most common Clean EGR valve
    Vacuum or EGR hose is connected to wrong post
    ECM
    P0440
    The fuel tank pressure is atmospheric pressure after the vehicle is driven for 20 min (2 trip detection logic).
    TSB for 5S-FE
    EG013-02 '98 and '99 Camry and Solara
    "Under certain driving conditions, some 1998 - 1999 model year Camry and Solara vehicles may exhibit a M.I.L. "ON" with DTCs P0440, P0441 and P0446 stored due to an inoperative Vapor Pressure Sensor
    3 way Vacuum Switching Valve (VSV). An improved Vapor Pressure Sensor VSV has been developed to correct this condition."
    TSB for 5S-FE 1998
    EG003-98
    Repair Procedure
    A. Diagnostics for PO441:
    1. Remove Vacuum Hoses between EVAP VSVand Charcoal Canister and discard.
    2. If there is a metal vapor pipe between
    EVAP VSV and Charcoal Canister, clean inside of vaporpipe
    3. Replace EVAP VSV and Charcoal Canister assembly with new parts.
    4. Install new vacuum hoses between EVAP VSV and Charcoal Canister.
    B. Diagnostics for P0446:
    1. Inspect vacuum hoses and pipes between EVAP (Purge) VSV and Charcoal Canister for leaks.
    2. Replace Vapor Pressure VSV and Canister.
    NOTE :When performing diagnostics for an occurrence of a MIL "ON" condition, Diagnostic Trouble Code (DTC) P0441 may be result of debris in Evaporative Emission Control System. This may cause blockage of a vapor line, or a stuck VSV, as described in troubleshooting area of Repair Manual.
    Possible Problems
    Fuel tank cap incorrectly installed <= Most common
    Fuel tank cap cracked or damaged (Toyota part only)
    Bad vapor pressure sensor/circuit
    Vacuum hose cracked, holed, blocked, damaged or disconnected
    Hose or tube cracked, holed, damaged, or loose
    Fuel tank/filler neck cracked, holed, or damaged
    Charcoal canister cracked, holed, or damaged (collision)
    In above description, check hoses between vapor pressur sensor and VSV for vapor pressure sensor and charcoal canister. Also, hose between charcoal canister and fuel tank.
    P0441 and/or P0446
    Possible Problems
    Open or short in VSV circuit for vapor pressure sensor
    Open or short in vapor pressure sensor circuit
    Vapor pressure sensor
    Open or short in VSV circuit for EVAP
    VSV for EVAP
    Vacuum hose cracks, hole, blocked, damaged or disconnected
    Charcoal canister cracks, hole, or damaged
    (P0446 is not normally associated with a loose or non-sealing gas cap. A loose or non-sealing gas cap triggers P0440)
    1. Check the VSV connector for EVAP, VSV connector for vapor pressure sensor and vapor pressure sensor connector for looseness and disconnection
    2. Check the vacuum hose between intake manifold and VSV for EVAP, VSV for EVAP and charcoal canister, charcoal canister and VSV for vapor pressure sensor, and VSV for vapor pressure sensor and vapor pressure sensor. Check these hoses for correct connection, looseness, cracks, holes, damage, and blockage.
    3. Check voltage between terminals VC and E2 of ECM connector (4.5-5.5 V). (replace ECM if faulty)
    4. Check voltages between terminals PTNK and E2 of ECM connector while applying vacuum to vapor pressure sensor (2.9-3.7 V).
    If faulty, check for open and short in harness and connector between vapor pressure sensor and ECM. If ok at this point, replace vapor pressure sensor.
    If voltage above is ok, Check VSV for EVAP. When ECM terminal EVP is grounded (ignition "ON"), Air should flow in pipe E (inboard on tube) on VSV and out F (outboard on tube) on VSV (Don't use high pressure air for this test). When EVP is not grounded, air does not flow in E and out F.
    5. Check operation of VSV for EVAP. Remove VSV from engine. Check that there is continuity between the two terminals (30-34 ohms). If there is no continuity, replace VSV for EVAP.
    Check that there is no continuity between either terminal and body. If there is continuity, replace VSV for EVAP.
    Check that air does not flow from inner port (E) to outboard port (F).
    Check that air flows from port E to F when you apply battery voltage across terminals. If no air flows, replace VSV for EVAP.
    6. Check the vacuum hose between intake manifold and VSV for EVAP, and VSV for EVAP and charcoal canister. Check as above.
    7. Check for open or short in harness and connector between EFI main-relay and VSV for EVAP and ECM. If faulty, repair or replace harness or connector. If ok, check and replace ECM.
    8. Check VSV for vapor pressure sensor. When ECM terminal TPC is grounded (ignition "ON"), Air should flow in pipe E (inboard on tube) on VSV and out F (outboard on tube) on VSV. When TPC is not grounded, air flows out G (outside of connector).
    If ok, check and replace charcoal canister.
    If not functioning correctly, check function of VSV for vapor pressure sensor. Remove from engine.
    Check that there is continuity between the terminals (33-39 ohms). Replace the VSV if there is no continuity.
    Check that air flows from port E (inboard in tube) to port G (side of connector).
    Check that air flows from port E to port F (outboard in tube) when battery voltage is applied across terminals. Replace VSV if function is incorrect.
    9. If good, Check the vacuum hose between charcoal canister and VSV for vapor pressure sensor, and vapor pressure sensor and VSV for vapor pressure sensor - check as above.
    11. Check for open and short in harness and connector between EFI main replay and VSV for vapor pressure sensor and ECM.
    Solenoid E (SL) is the torque converter lock-up solenoid. If the torque converter is a little slow locking up, it will set this code. May only be a one-time thing owing to a small particle of something getting jammed in the solenoid. The code may disappear by itself.
    If it doesn't right away, check out the color of your tranny fluid. If it is pretty much red or brown and smells ok, then flush the tranny and see if that gets rid of the code. If not, pull out some fluid and add a bottle of Seafoam Trans Tune and run it for 1 or 2k miles. Then flush the transmission again. Check if the code is gone.
    If this problem persists, I've been told you'll have to replace the E-solenoid.
    There is a Service Bulleting (EG006-00) issued for '00 Siennas on this problem. They get a new torque converter to fix the problem permanently.
    The following discussion was submitted by csaxon:
    The ECM uses signals from throttle position sensor, airflow meter and crankshaft position sensor to monitor engagement of Torque Converter Clutch (TCC).
    The ECM compares engagement condition of TCC with lock-up schedule in memory to detect MECHANICAL trouble of lock-up solenoid, valve body and torque converter. A P0700 trouble code is set when TCC lock-up does not occur during appropriate speed, or lock-up does not release at appropriate speed.
    Possible causes are:
    * Solenoid is stuck open or closed.
    * Valve body clogged or valve stuck.
    * TCC malfunction.
    There are simple electrical tests to check the solenoid and plunger but the transmission pan must be removed to gain access.
    As Brian suggests, if you haven't had your system flushed or changed in awhile it may help but I'm not sure that's cheaper than actually removing the pan and checking the solenoid.
    The Toyota service tech can check the system without pan removal with his analyzer.
    Dura Lex sed Lex
    Feb 2001
    Leiria
    Já não me lembra de onde tirei isto tudo :) acho que foi aqui: http://www.automotiveforums.com/vbul...=586540&page=3
    Mas aqui vai mais um complemento de ajuda....
    http://alflash.com.ua/OBDII/DTCe1.pdf
    Dura Lex sed Lex
    Mar 2007
    Olá Kalu!
    EXCELENTE trabalho este post!;...
    Faz tempo que tenho este problema no meu corolla de 2001 :
    (P1346 VVT Sensor /Camshaft Position Sensor Circuit Range/Performance Problem (Bank 1))
    já substitui o medidor de massa de ár e continua igual agora vou comprar o sensor de arvore de cames, será a ultima solução que tentarei antes de levar o carro a oficina, gostaria de preguntar se alguem sabe como medir os Volts e os omhs destas duas peças
    1 Abraço
    Feb 2001
    Leiria
    acho que há por ai uns manuais eléctricos dos corollas, penso que tem isso.
    Verifica este tópico e faz o download do ficheiro, verifica se tem alguma coisa!
    http://www.toyotistas.com/forum/info...la-2004-a.html
    Não é do mesmo ano mas pode ter o que queres
    Dura Lex sed Lex
    Oct 2008
    Amadora
    Quote Mensagem Original de Mvilar Ver Mensagem
    Olá Kalu!
    1 Abraço
    estas no mau caminho, e isso por tentativas acho que vais gastar mais dinheiro do que ires logo a marca fazer um diagnostico como deve ser. o que deve ser prai um 25 eur.
    a partida esse codigo deve-se a sensibilidade do proprio com********************dor do motor.
    quando paras o motor e conforme a posicao da cambota as vezes na ultima volta da mesma, ela tem de andar para tras (no sentido inverso a rotacao do motor) devido ao peso dos contrabalancos, o que faz os pistons tb rodarem e ao contrario e consequantemente as arvore de cams (estamos a falar de mm).
    mas mesmo assim pode ser o suficiente para gerar um codigo destes,
    so da para saber isso indo ao registo do codigo, ou seja ver em k momento e k o codigo foi detectado, saber posicao de acelerador, tempos de injecao e rotacao do motor.
    e para isso k servem os diagnosticos da marca.
    TOYOTA AURIS - NDE150
    TOYOTA YARIS - NCP13
    May 2006
    Turquel
    O meu tsport agora anda com esta avaria o que sera?Ja estive a ver a gr do carro e esta bom nao consigo descobrir o que e.Alguem sabe?
    May 2006
    Turquel
    Feb 2001
    Leiria
    P0410 OBD-II Trouble Code
    Technical Description
    What does that mean?
    The P0410 code refers to the emissions system. The AIR pump puts air to the exhaust to lower emissions. It takes in outside air and pumps it through two one-way check valves into each bank of the exhaust.
    About 90% of the time that this code is set, the one-way check valves have worn out or failed and allow water (which occurs naturally in the exhaust) back into the pump. In any cold climate, especially in climates with higher humidity, this water may be more excessive. The water partially fills the AIR pump, it can then freeze. When the PCM commands the pump on, if the pump is frozen it cannot turn, thus overloading the circuit and "popping" the fuse.
    Symptoms
    Possibly symptoms include:
    • MIL illumination obviously
    • Hesitation on acceleration
    • Noise from a bad/stuck AIR pump
    Causes
    A code P0410 may mean that one or more of the following has happened:
    • Water may have collected in the AIR pump or the vent solenoid and frozen or corroded the pump
    • Blown AIR pump fuse due to freezing up
    Possible Solutions
    Note: There is a technical service bulletin (TSB) regarding this code for a number of Toyota models. The TSB calls for the replacement of the AIR pump and the installation of a new secondary injection hose.
    Additionally, if you simply replace the AIR pump the problem may return again (and again). If you replace the pump, also clean out the hoses and replace the one-way check valve. If this is on a Toyota model that the TSB applies to, follow those instructions in the link above. In a few cases, people have put a small hole in the rubber cover on the pump which allows any water to drain out.
    Also, please note that this may be covered under the emissions warranty on the vehicle. If your vehicle is out of bumper-to-bumper warranty, check if the emissions warranty is still valid!
    • Replace the AIR pump AND one-way check valve
    • Test and clean the AIR pump AND test and replace the one-way air check valve
    • Replace the AIR pump inlet hose
    • Replace the AIR pump fuse (found under the hood)
    Dura Lex sed Lex
    Oct 2010
    Loulé, Algarve, Portugal
    tenho o cabo e adaptador. alguem tem um software compativel para o auris 2010 ?
    ---------- Mensagem adicionada em 11:11 PM ---------- Mensagem anterior em 11:10 PM ----------
    já agora ... podemos alterar alguma coisa ? que de jeito alterar ?
    Quote Mensagem Original de carlos miranda Ver Mensagem
    Post na secção errada do fórum.Aconselho a leitura atenta das regras do fórum
    http://www.toyotistas.com/forum/gera...-do-forum.html
  1. [Informação] Toyota - Códigos dos motores
    By T-Sport in forum Informação Técnica
    Respostas: 11
    Última Mensagem: 12-05-2012, 20:05 PM
  2. Toyota Corolla 1.4 97 Cv de 2001 - Luz de aviso de avaria
    By frdavid in forum Perguntas & Respostas sobre Técnica
    Respostas: 36
    Última Mensagem: 16-01-2009, 11:23 AM
  3. Avaria no Corolla xli 93
    By eNr1k_ in forum Geral Toyotistas®
    Respostas: 10
    Última Mensagem: 04-07-2007, 19:30 PM
  4. os códigos Toyota:
    By filda pawa in forum Geral Toyotistas®
    Respostas: 6
    Última Mensagem: 21-07-2005, 21:55 PM
  5. Códigos dos modelos Toyota
    By AMPO in forum Geral Toyotistas®
    Respostas: 4
    Última Mensagem: 20-07-2005, 20:52 PM
