Resultados 1 a 10 de 10
Tópico: Compilação de DIY p/ YarisII
28-05-2010, 11:10 AM #1
Encontrei isto No site Yaris world, ja devem conhecer, achei que era interessante, ta em ingles mas acho que dá para perceber bem, tem muitos passo a passo com fotos.
Espero que possa ser util a alguem
Interior
How to remove the Backseats : http://www.yarisworld.com/forums/showthread.php?t=306
Sparco Raceseat Installation : http://www.yarisworld.com/forums/showthread.php?t=360
Install a Tachhttp://www.yarisworld.com/forums/showthread.php?t=662
Oil Pressure Gauge Install: http://www.yarisworld.com/forums/showthread.php?t=15233
30 sec Door Panel Removal - http://www.yarisworld.com/forums/showthread.php?t=2305
Remove Door Panels: http://www.yarisworld.com/forums/showthread.php?t=15011
Big Foot Mod - http://www.yarisworld.com/forums/sho...t=big+foot+mod
Center Control Knob Color Change - http://www.yarisworld.com/forums/showthread.php?t=2275&
Change Radio/Radio LCD Color - http://www.yarisworld.com/forums/showthread.php?t=2853
Change Your Gauge Cluster Color (sedan)Here - http://www.yarisworld.com/forums/showthread.php?t=2928
Interior Light Color Change: http://www.yarisworld.com/forums/showthread.php?t=9857
Paint interior panels: http://www.yarisworld.com/forums/showthread.php?t=4079
Discreet Mounting of 12v Adapter - http://www.yarisworld.com/forums/showthread.php?t=1934
Power Outlet Mod - http://www.yarisworld.com/forums/showthread.php?t=1542
Powered USB Ports: http://www.yarisworld.com/forums/showthread.php?t=9431
Replace Door Panel Fabric: http://www.yarisworld.com/forums/showthread.php?t=5991
Front Seat Modification: Increase Thigh Support: http://www.yarisworld.com/forums/showthread.php?t=9833
Clazzio Seat Cover Install: http://www.yarisworld.com/forums/showthread.php?t=11925
TRD Shift Knob Install: http://www.yarisworld.com/forums/showthread.php?t=11493
Cabin Air Filter: http://www.yarisworld.com/forums/showthread.php?t=8828
Install variable wiper control stalk: http://www.yarisworld.com/forums/showthread.php?t=15512
Electronics/Sound System/Security
How to change the Stereo headunit : http://www.yarisworld.com/forums/showthread.php?t=225
Disable Daytime running Lights : http://www.yarisworld.com/forums/showthread.php?t=894
Disable Daytime Running Lights - http://www.yarisworld.com/forums/showthread.php?t=1881
Install Grounding Kit: http://www.scionlife.com/forums/view...ight=grounding
Replacing Stock Deck: http://www.yarisworld.com/forums/showthread.php?t=556
Removing Door Speakers: http://www.yarisworld.com/forums/showthread.php?t=1718
Install HIDs - http://www.yarisworld.com/forums/sho...&postcount=114
3dr Speaker Install - http://www.yarisworld.com/forums/sho...8537#post38537
Keyless Entry Install: http://www.yarisworld.com/forums/showthread.php?t=9565
Add Remote to Factory Keyless Entry - http://www.yarisworld.com/forums/showthread.php?t=1526
Power Rear Hatch - http://www.yarisworld.com/forums/sho...t=remote+hatch
Bypass Tire Pressure Monitoring System ('08 and up): http://www.yarisworld.com/forums/showthread.php?t=11058
Braille Battery Install: http://www.yarisworld.com/forums/showthread.php?t=13719
Headlights Off with the Ignition Switch: http://www.yarisworld.com/forums/showthread.php?t=14427
Install Trombe Stebel Nautolus Horn: http://www.yarisworld.com/forums/showthread.php?t=9423
Unlink AC From Defroster: http://www.yarisworld.com/forums/showthread.php?t=10888
Engine/Exhaust/Transmission
Megan Header Install - http://www.yarisworld.com/forums/showthread.php?t=2986
NST CR-Lite pulley install: http://www.yarisworld.com/forums/showthread.php?t=3964
DIY $30 intake: http://www.yarisworld.com/forums/showthread.php?t=4392
$30 Oil Catch Can: http://www.yarisworld.com/forums/sho...9085#post79085
Install Greddy Exhaust: http://www.yarisworld.com/forums/showthread.php?t=6691
1.8L (1ZZ) Throttle Body Connector Chip Swap: http://www.yarisworld.com/forums/showthread.php?t=14672
NST Short Shift Kit Install: http://www.yarisworld.com/forums/showthread.php?t=7533
Intake Install: http://www.yarisworld.com/forums/showthread.php?t=8278
AEM Intake install: http://www.yarisworld.com/forums/showthread.php?t=9582
NST Shifter Bushings: http://www.yarisworld.com/forums/showthread.php?t=9585
Suspension/Brakes
Tanabe Spring Install : http://www.yarisworld.com/forums/showthread.php?t=1096
Spring Install: http://www.yarisworld.com/forums/showthread.php?t=15135
Megan Coilover Install: http://www.yarisworld.com/forums/showthread.php?t=9124
Strut Tower Bar Install - http://www.yarisworld.com/forums/showthread.php?t=2285
Type 1 Lower Bar Install -http://www.yarisworld.com/forums/showthread.php?t=1227
Rear Sway Bar: http://www.yarisworld.com/forums/showthread.php?t=14084
Rear Drum Brakes/Parking Brake Adjustment: http://www.yarisworld.com/forums/showthread.php?t=12333
RunStop rear Disc Brake upgrade: http://www.yarisworld.com/forums/showthread.php?t=12489
Exterior
Baking and Painting Headlightshttp://www.yarisworld.com/forums/showthread.php?t=1525
Remove Emblems Vid - http://www.yarisworld.com/forums/showthread.php?t=2679
De-badge Your Rear End - http://www.yarisworld.com/forums/showthread.php?t=938
Hatch-back Spoiler Install - http://www.yarisworld.com/forums/showthread.php?t=661
Tint/Vinyl Your Tail Lights - http://www.yarisworld.com/forums/showthread.php?t=1596
Side Market Bulb swap: http://www.yarisworld.com/forums/showthread.php?t=4106
eBay Fog Lights Install: http://www.yarisworld.com/forums/showthread.php?t=3471
Additional Fog light install info: http://www.yarisworld.com/forums/showthread.php?t=15197
Another fog light Install (ESUSE brand): http://www.yarisworld.com/forums/showthread.php?t=9473
LED Side Mirror Cover install: http://www.yarisworld.com/forums/showthread.php?t=6447
Side mirror cover and wing install: http://www.yarisworld.com/forums/showthread.php?t=9313
Sedan Spoiler Install - http://www.yarisworld.com/forums/showthread.php?t=8595
JDM RS taillight (OEM) Install: http://www.yarisworld.com/forums/showthread.php?t=7224
JDM RS taillights (replica) Install: http://www.yarisworld.com/forums/showthread.php?t=9692
Smoke (paint) Sedan headlights: http://www.yarisworld.com/forums/showthread.php?t=13521
Fixing a dent with a hairdryer: http://www.yarisworld.com/forums/showthread.php?t=13917
Install Sedan Mesh Grille: http://www.yarisworld.com/forums/showthread.php?t=12090
Install LB Halo Projector Headlights: http://www.yarisworld.com/forums/showthread.php?t=9430
Sealing the Hood: http://www.yarisworld.com/forums/showthread.php?t=10035
Mileage Improvers
Engine Grill Block - http://www.yarisworld.com/forums/showthread.php?t=8985
Misc
Custom Trunk Liner - http://www.yarisworld.com/forums/showthread.php?t=1211
Undercoating Your Inner Wheel Wells -http://www.yarisworld.com/forums/showthread.php?t=904
10 Minute Engine Bay Detail: http://www.yarisworld.com/forums/showthread.php?t=4729
Hood damper: http://www.yarisworld.com/forums/showthread.php?p=10209
DIY Hood Damper: http://www.yarisworld.com/forums/showthread.php?t=15219
Hood Insulator Install: http://www.yarisworld.com/forums/showthread.php?t=12627
Ghetto Camcorder mount: http://www.yarisworld.com/forums/showthread.php?t=2872
Low (no)-cost Camcorder mount: http://www.yarisworld.com/forums/showthread.php?t=15642
Turn off VSC and TRC (European models only): http://www.yarisworld.com/forums/showthread.php?t=12487
Wiper Cowl removal: http://www.yarisworld.com/forums/showthread.php?t=9581
Brake Cooling/Cold Air Intake ducts: http://www.yarisworld.com/forums/showthread.php?t=8333
Lower Windshield Rattle Fix: http://www.yarisworld.com/forums/showthread.php?t=9081
General Maintenance
Manual Tranny Oil Change - http://www.yarisworld.com/forums/showthread.php?t=8912
Brake Pad Change: http://yarisworld.com/forums/showthread.php?t=4530
Myke Yaris 1.0 2006
29-05-2010, 09:00 PM #2
Bem quem tiver um Yaris... é um sortudo!! Grande tópico Mike!
31-05-2010, 08:31 AM #3
Pois acho que é um topico muito util, mas parece que a maior parte dos yaris daki do forum são da 1ª geração. Acho que tem muitos DIY porreiros.
Espero que ajude o pessoal. hehe
Myke Yaris 1.0 2006
02-06-2010, 09:33 PM #4
Vês como és um gajo ultra porreiro pá!!!
Na falta de 1 tenho 2 Toyotas!!!! Excelente!!!!
04-06-2010, 11:39 AM #5
Porreiro pá....
Myke Yaris 1.0 2006
22-12-2010, 01:45 AM #6
BANIDO!
- Jan 2010
- Lisboa
- 148
excelente topico
28-01-2011, 01:04 PM #7
- Sep 2010
- Gaia
- 176
- Thanked 2 Times in 2 Posts
Muito bom :)
02-02-2011, 09:35 AM #8
Myke Yaris 1.0 2006
04-02-2011, 11:35 AM #9
Isto é o que eu chamo um tesouro de tópico ***** Muito bom mesmo Myk3 :D
07-03-2011, 07:18 PM #10
Encontrei mais isto....
http://www.etimago.com/yaris/repairmanual/ tem aqui coisas que vêm a completar aquilo que o Myk3 já colocou :)
Tags for this Thread
