Resultados 1 a 5 de 5
Tópico: [Informação] ST205 3S-GTE Engine
28-09-2006, 09:12 PM #1
[size=18px]ST205 3S-GTE Engine [/size]
Here are some engine shots: (Clicar na img para aumentar)
End view of 3S-GTE, showing the smooth cambelt cover introduced with this model
The front view. Note that the turbo and downpipe had not been fitted at this stage.
The special valve for the Group A model is to the right of the IC inlet pipe.
Note the block has been painted silver, it is cast steel.
The aluminium sump pan (HPC coated) has a pressed steel section right at the bottom.
The rear view clearly shows the angle the engine is mounted on!
The IC at the top is almost flat in the car.
Now with the turbo fitted.
Visible are the BOV valve for the antilag system (just above turbo outlet,
with pipes disappearing under the manifold heatshield) and one of the antilag fittings on the manifold
(visible between yellow dipstick and lifting hook at left of photo).
These are the valves on the back of the block specific to the Group A model's antilag system.
There is a vacuum canister, two VSV's and lots of hoses!
The inlet manifold off the engine.
Note the ports are far smaller than the earlier engine due to lack of TVIS.
The back view showing the well shaped runners.
[size=12px]Fonte - http://gtfour.supras.org.nz [/size]
13-01-2008, 02:54 PM #2
bem ja vi umas cenas na net que ha pessoal com corolla's e10 com esse magano la dentro!!!!
e akilo ripa e bem!!!XLi rulaaa
13-01-2008, 08:04 PM #3
onde posso arranjar um destes???
13-01-2008, 10:43 PM #4
bom post ;)
13-01-2008, 10:58 PM #5
num SC perto de si!!! isto e k e grande motor!!!
ST205 3S-GTE Rev3 Engine supplement
By Hugo_Ferraz in forum DownloadsRespostas: 6Última Mensagem: 13-11-2008, 02:11 PM -
ST205 Repair Manual - Suplement chassis and body
By Hugo_Ferraz in forum DownloadsRespostas: 0Última Mensagem: 11-11-2008, 05:05 PM -
Valor Toyota Celica ST205
By fabio.dias in forum Geral Toyotistas®Respostas: 1Última Mensagem: 10-05-2007, 11:26 PM -
[Informação] Manual de Reparação - 4A-F, 4A-GE engine
By FastPeter in forum Perguntas & Respostas sobre TécnicaRespostas: 2Última Mensagem: 23-03-2006, 08:48 PM -
Motor ST205 num celica S182
By |Ripas| in forum Perguntas & Respostas sobre TécnicaRespostas: 3Última Mensagem: 20-10-2005, 11:47 AM
