Resultados 1 a 3 de 3
Tópico: [INFO] - L, 2L, 2L-T Engine Repair Manual
    Nov 2006
    Ermesinde / Porto
    Default [INFO] - L, 2L, 2L-T Engine Repair Manual
    O manual de serviço contem os procedimentos de reparação para os motores:
    L - 2.2L diesel, 2L - 2.4L diesel, 2L-T - 2.4L diesel (Versão turbo do 2L)
    muito útil principalmente para quem tem Hiace e/ou Hilux, visto partilharem estas motorizações.
    Eu já imprimi e juntei à "tralha" literária que tenho sobre a Hiace ;)
    Contents:
    * INTRODUCTION
    o HOW TO USE THIS MANUAL
    o IDENTIFICATION INFORMATION
    o GENERAL REPAIR INSTRUCTIONS
    o ABBREVIATIONS USED IN THIS MANUAL
    * ENGINE MECHANICAL
    o DIESEL ENGINE DIAGNOSIS
    o DIESEL ELECTRICAL SYSTEM DIAGNOSIS
    o ENGINE TUNE-UP
    o COMPRESSION CHECK
    o TIMING BELT [ Components ~ Removal of Timing Belt ~ Inspection of Components ~ Installation of Timing Belt ]
    o CYLINDER HEAD [ Components ~ Removal of Cylinder Head ~ Disassembly of Cylinder Head ~ Inspection, Cleaning and Repair of Cylinder Head Components ~ Replacement of Camshaft Oil Seal ~ Assembly of Cylinder Head ~ Installation of Cylinder Head onlinefreeebooks.net]
    o CYLINDER BLOCK [ Components ~ Disassembly of Cylinder Block ~ Inspection of Cylinder Block ~ Disassembly of Piston and Connecting Rod Assembly ~ Inspection of Piston and Connecting Rod Assembly ~ Replacement of Connecting Rod Bushing ~ Inspection and Repair of Crankshaft ~ Boring of Cylinders ~ Repfacemellt of Crankshaft Oil Seals ~ Assembly of Piston and Connecting Rod Assembly ~ Installation of Crankshaft, Piston and Connecting Rod Assembly ~ Assembly of Cylinder Block ]
    * FUEL SYSTEM
    o REPLACEMENT OF FUEL FILTER
    o FUEL FILTER WARNING SWITCH
    o FUEL HEATER
    o INJECTION NOZZLES
    o INJECTION PUMP
    * COOLING SYSTEM
    o TROUBLESHOOTING
    o CHECK AND REPLACEMENT OF ENGINE COOLANT
    o WATER PUMP
    o THERMOSTAT
    o RADIATOR
    * LUBRICATION SYSTEM
    o TROUBLESHOOTING
    o OIL PRESSURE CHECK
    o REPLACEMENT OF ENGINE OIL AND OIL FILTER
    o OIL PUMP
    o OIl COOLER AND RELIEF VALVES
    * STARTING SYSTEM
    o PRE-HEATING SYSTEM
    o TROUBLESHOOTING
    o STARTING SYSTEM CIRCUIT
    o STARTER
    o STARTER RELAY
    * CHARGING SYSTEM
    o PRECAUTIONS
    o TROUBLESHoOTING
    o CHARGING SYSTEM CIRCUIT
    o ON-VEHICLE INSPECTION
    o ALTERNATOR
    o ALTERNATOR REGULATOR
    o CHARGE LIGHT RELAY
    o MAIN RELAY
    * SERVICE SPECIFICATIONS
    o ENGINE MECHANICAL
    o FUEL SYSTEM
    o COOLING SYSTEM
    o LUBRICATION SYSTEM
    o STARTING SYSTEM
    o CHARGING SYSTEM
    * TOYOTA L, 2L ENGINE REPAIR MANUAL FOR 2L-T ENGINE DESTINATIONS - (the following sections contain only the pOints which differ from the previous sections of this manual)
    o ENGINE MECHANICAL [ TURBOCHARGER DIAGNOSIS ~ TURBOCHARGER ELECTRICAL SYSTEM ~ DIAGNOSIS ~ TURBOCHARGER ]
    o FUEL SYSTEM [ FUEL HEATER ~ INJECTION PUMP ]
    o SERVICE SPECIFICATIONS [ ENGINE MECHANICAL ~ FUel SYSTEM ]
    Download Links:
    * INTRODUCTION (0.6 MB pdf file): 01 - Introduction.pdf
    * ENGINE MECHANICAL (5.4 MB pdf file): 02 - Engine Mechanical
    * FUEL SYSTEM (3.8 MB pdf file): 03 - Fuel System
    * COOLING SYSTEM (0.5 MB pdf file): 04 - Cooling System
    * LUBRICATION SYSTEM (0.7 MB pdf file): 05 - Lubrification System
    * STARTING SYSTEM (1.7 MB pdf file): 06 - Starting System
    * CHARGING SYSTEM (1.6 MB pdf file): 07 - Charging System
    * SERVICE SPECIFICATIONS (1.1 MB pdf file): 08 - Service Spec's
    * TOYOTA L, 2L ENGINE REPAIR MANUAL FOR 2L-T ENGINE DESTINATIONS (1.4 MB pdf file): 09 - 2L-T
  2. Os seguintes utilizadores agradeceram a fabio.dias pela participação:
    Carlos Sol (21-09-2012)
  3. #2
    Jun 2012
    Ora aí está uma coisa interessante.
  4. #3
    Jun 2012
    Se funcionasse claro!
