O manual de serviço contem os procedimentos de reparação para os motores:
L - 2.2L diesel, 2L - 2.4L diesel, 2L-T - 2.4L diesel (Versão turbo do 2L)
muito útil principalmente para quem tem Hiace e/ou Hilux, visto partilharem estas motorizações.
Eu já imprimi e juntei à "tralha" literária que tenho sobre a Hiace ;)
Contents:
* INTRODUCTION
o HOW TO USE THIS MANUAL
o IDENTIFICATION INFORMATION
o GENERAL REPAIR INSTRUCTIONS
o ABBREVIATIONS USED IN THIS MANUAL
* ENGINE MECHANICAL
o DIESEL ENGINE DIAGNOSIS
o DIESEL ELECTRICAL SYSTEM DIAGNOSIS
o ENGINE TUNE-UP
o COMPRESSION CHECK
o TIMING BELT [ Components ~ Removal of Timing Belt ~ Inspection of Components ~ Installation of Timing Belt ]
o CYLINDER HEAD [ Components ~ Removal of Cylinder Head ~ Disassembly of Cylinder Head ~ Inspection, Cleaning and Repair of Cylinder Head Components ~ Replacement of Camshaft Oil Seal ~ Assembly of Cylinder Head ~ Installation of Cylinder Head onlinefreeebooks.net]
o CYLINDER BLOCK [ Components ~ Disassembly of Cylinder Block ~ Inspection of Cylinder Block ~ Disassembly of Piston and Connecting Rod Assembly ~ Inspection of Piston and Connecting Rod Assembly ~ Replacement of Connecting Rod Bushing ~ Inspection and Repair of Crankshaft ~ Boring of Cylinders ~ Repfacemellt of Crankshaft Oil Seals ~ Assembly of Piston and Connecting Rod Assembly ~ Installation of Crankshaft, Piston and Connecting Rod Assembly ~ Assembly of Cylinder Block ]
* FUEL SYSTEM
o REPLACEMENT OF FUEL FILTER
o FUEL FILTER WARNING SWITCH
o FUEL HEATER
o INJECTION NOZZLES
o INJECTION PUMP
* COOLING SYSTEM
o TROUBLESHOOTING
o CHECK AND REPLACEMENT OF ENGINE COOLANT
o WATER PUMP
o THERMOSTAT
o RADIATOR
* LUBRICATION SYSTEM
o TROUBLESHOOTING
o OIL PRESSURE CHECK
o REPLACEMENT OF ENGINE OIL AND OIL FILTER
o OIL PUMP
o OIl COOLER AND RELIEF VALVES
* STARTING SYSTEM
o PRE-HEATING SYSTEM
o TROUBLESHOOTING
o STARTING SYSTEM CIRCUIT
o STARTER
o STARTER RELAY
* CHARGING SYSTEM
o PRECAUTIONS
o TROUBLESHoOTING
o CHARGING SYSTEM CIRCUIT
o ON-VEHICLE INSPECTION
o ALTERNATOR
o ALTERNATOR REGULATOR
o CHARGE LIGHT RELAY
o MAIN RELAY
* SERVICE SPECIFICATIONS
o ENGINE MECHANICAL
o FUEL SYSTEM
o COOLING SYSTEM
o LUBRICATION SYSTEM
o STARTING SYSTEM
o CHARGING SYSTEM
* TOYOTA L, 2L ENGINE REPAIR MANUAL FOR 2L-T ENGINE DESTINATIONS - (the following sections contain only the pOints which differ from the previous sections of this manual)
o ENGINE MECHANICAL [ TURBOCHARGER DIAGNOSIS ~ TURBOCHARGER ELECTRICAL SYSTEM ~ DIAGNOSIS ~ TURBOCHARGER ]
o FUEL SYSTEM [ FUEL HEATER ~ INJECTION PUMP ]
o SERVICE SPECIFICATIONS [ ENGINE MECHANICAL ~ FUel SYSTEM ]
Download Links:
* INTRODUCTION (0.6 MB pdf file): 01 - Introduction.pdf
* ENGINE MECHANICAL (5.4 MB pdf file): 02 - Engine Mechanical
* FUEL SYSTEM (3.8 MB pdf file): 03 - Fuel System
* COOLING SYSTEM (0.5 MB pdf file): 04 - Cooling System
* LUBRICATION SYSTEM (0.7 MB pdf file): 05 - Lubrification System
* STARTING SYSTEM (1.7 MB pdf file): 06 - Starting System
* CHARGING SYSTEM (1.6 MB pdf file): 07 - Charging System
* SERVICE SPECIFICATIONS (1.1 MB pdf file): 08 - Service Spec's
* TOYOTA L, 2L ENGINE REPAIR MANUAL FOR 2L-T ENGINE DESTINATIONS (1.4 MB pdf file): 09 - 2L-T
