Autocar ao volante do Lexus IS300h
  • Autocar ao volante do Lexus IS300h
    First drive review: Lexus IS 300h
    Lexus’s German-baiting hybrid promises remarkable diesel-beating CO2 figures in a compact, agile, rear-drive format
    What is it?
    This is an early prototype of the all-new Lexus IS. The IS isn't being launched until the Detroit show in mid-January so much of the car's detail, including the interior and exterior styling, was under wraps for this drive. The UK will be getting two models: a V6 petrol-powered IS250 (which is mainly for the model's UK private buyers), and the new IS300h driven here, which combines a 2.5-litre, four-cylinder petrol engine with an electric motor and a battery pack.
    This latter car is intended to be Lexus’s big breakthrough in the UK’s CO2-driven fleet market. Remarkably, Lexus is aiming to get the IS300h certified at "under 100g/km". The new car is based on the same new rear-drive platform as the recently-launched GS, although the wheelbase has been shortened and the track is also slightly narrower.
    Lexus's engineers say the structure is extra-stiff, using 25 metres of adhesive, extra spot welds and a new technique called laser screw welding in its construction. The double-wishbone front suspension set-up gets stiffer anti-roll bars and softer spring rates (to try to improve the ride without sacrificing handling), and the multi-link rear suspension is new. The biggest advance is the redesigned CVT transmission, which finally eliminates the widely disliked mismatch between engine speed and vehicle speed so typical of previous CVT ‘boxes.
    The interior styling is close to that of the CT compact hatchback. There are two centre console dials, one for the multimedia system and one for switching the chassis between Eco, Normal, Sport and Sport+ modes.
    What is it like?
    On the short track course on which we drove it, the IS300h was swift and surprisingly capable, with good brakes and fine stability. However, compared to the agile V6 petrol IS, the hybrid was slower to respond to steering inputs and was less keen on rapid direction changes. The extra weight of the electric motor in the nose and the battery packs in the rear are to blame.
    On the road, the IS300h is refined and easygoing. It’s fluid on winding roads and has a decent amount of bite in the steering. The overwhelming sense is of effortless progress with a reasonable dash of driver involvement. It is also impressively swift to switch into EV mode in urban traffic, something other hybrids are reluctant to do. It was hard to be definitive about by the ride, which was excellent on smooth roads but thumped somewhat on broken Los Angeles concrete.
    Should I buy one?
    If you're fed up with rattling and thrumming four-cylinder premium-car diesel engines (which have generally become less refined since the EU5 regulations), the IS 300h could be a very tempting alternative to the German oil-burners. However, only when we establish the real-world economy and have driven it on European roads, and once the pricing is etablished, will be able to get a definitive answer.
    Lexus IS300h
    Price: £32,000 (est); 0-62mph: 6.9sec (est); Top speed: 140mph (est); Economy: 73mpg (combined, est); CO2: 99g/km (est); Kerbweight: 1765kg (est); Engine type: 4-cyls, 2499cc, petrol; Power: 240bhp (est); Torque: n/a; Gearbox: CVT
    Fonte: First drive review: Lexus IS 300h Review | Autocar
    O texto tem um erro. A relação entre o consumo e o CO2 indicada é para combustível diesel.
    Com 99g/km, o consumo combinado estimado será de 4,2l/100km (67MPG uk) de gasolina.
      Um pequeno video da versão "normal" :fixe
        Confirmado o "sob-capot" mais actual da gama híbrida!
        Terá o 2.5 Atkinson com "cabeça" D4S...
        Lexus Premieres New Lexus 'IS' Sports Sedan at Detroit Auto Show | TOYOTA MOTOR CORPORATION GLOBAL WEBSITE
        220cv nominais, 174cv do motor térmico
