*********************************MOD LIST********************************* Engine: Toyota AE111 4A-GE "blacktop" 105mm Velocity Stacks HKS 4-1 Race Header NST Pulley kit Splitfire 8.8mm spark plug wires NGK Iridium spark plugs Buddy Club Racing Spec Condenser Pivot Ground Wires NRG ground terminal Cusco Oil Catch Can Trust Oil Cooler, Radiator TRD Thermostat Billion Radiator Hose Drive Train: Toyota AE111 C160 6 speed LSD transaxle Racing Gear flywheel Exedy Stage 1 clutch Speed Source solid shifter cable bushings TRD Short Shifter w/ solid Shift base bushings Suspension/Wheels/Brakes: Cusco Zero2 Coilover/dampeners w/ F & R upper pillow ball mounts & Camber Plates Swift 10/8Kg/mm Springs SPC Rear Camber Bolts TRD Japan 3pt front strut tower bar Whiteline "oversized" rear sway bar (20mm, 3ways adjustable) OEM front sway bar w/ Whiteline SuperPro poly bushings (22mm) SuperPro front control arm pivot, caster, and rear trailing arm bushings Cusco/Safety 21 4pt roll bar C-pillar bar Do-Luck floor bar - 15X7 Rays Engineering Gram Lights 57C (gunmetal) Rays Engineering Extended Duralinum lugnuts 205/50/15 Falken Azenis RT-615 - Powerslot front rotors Hawk HP+ pads AE111 Levin rear disc conversion Exterior: Toyota Japan AE101 FX front bumper Toyota Japan AE101 Koito Crystal Black Housing Headlamps Depo AE101 FX clear bumper lamps DC2 ITR front lip (modified to fit) Toyota Japan AE101 sedan rain guards Adjustable front license plate bracket Hella Micro DE Ion Yellow fog lamps ModExpress 6000K bixenon HID JDM AE100 BZ Touring OEM side skirts EDM AE101 rear bumper Toyota Japan taillights w/ superflux LED conversion Toyota Japan trunk panel w/ custom license plate relocation M3 rear lip spoiler Custom painted IS300 Graphite Grey Pearl (1C6) 35% tint all around Toyota SE Black Pearl badges Circuit Hero tow hook Interior: Recaro Profi SPG driver seat w/ MemoryFab Super Low rails Recaro SRD (suede) passenger seat Willans 6pt camlock harness (blue) Celica GT-S steering wheel interior fully reupholstered w/ black sued w/ blue stitching CyberSpeed adjustable shift knob Cusco ebrake button/knob Razo Competition Ti adjustbale gas pedal, dead pedal and floor plate Defi VSD Concept HUD oil pressure, oil temperature and water temperature gauges Custom made center console triple gauge pod ICE: KDC-X991 Kenwood excelon CD/MP3/USB headunit with g-sensor JBL 180.2 Amp JL Audio 6.5" XR Component set w/ dome teweeters & crossovers custom fiberglass door speaker pods Infinity Basslink Future Mods: JDM AE101 Power Folding Mirrors (to be installed) Weapon R Engine Dampener (to be installed) Ultra Racing rear strut bar & Under brace Fastbrakes Wilwood BBK Toda camshafts Toda valve springs Toda cam gear TRD 0.8mm headgasket (11.7:1 CR w00t) Greddy Emanage blue w/ AE111 PnP harness |
Sem palavras !
Um dia quem sabe ... :)
FONTE
