Retirado de outro fórum.
Scans from a training manual.
Power/weight:
HP: 147kw (200ps) / 200hp @7000rpm
Torque: 205nm (151 lb/ft) @ 6600rpm
Weight:
2662 ponds (1210kg) for base manual (~ 2580 lbs dry weight)
2706 pounds for higher trim manual
Columns:
First 2 column are for "small FR sport", column 1 is a higher spec model, column 2 is a lower spec model. 3rd column is Mx5/Miata, 4th is RX8 and last is CRZ. It's a comparison chart.
Top Section:
The top section is the dimension in mm, length width height wheelbase, ground clearance then number of seats. Next is weight.
Top spec manual is 1230kg, auto is 1250kg.
Low spec manual is 1210kg, auto is 1230kg.
Then its turning radius.
High spec rides on 17" wheels and low spec on 16.
Second Section:
This section is engine. Boxer 4 DOHC, 1998cc. Output as listed on 1st post above. Drinks unleaded and 50L fuel tank.
Fuel consumption:
13.4 km/l
31.52 mpg
50.72 km/g
Third Section:
This section is front engine/rear drive, transmission type, suspension type, brake then tyre size.
Last Section:
Last section is equipment which is not that easy to understand. First thing I notice is top spec has LSD for manual and auto while low spec only has LSD on manual. I'll post more if I can read more.
More update:
Both spec have VSC, front passenger and front and rear curtain bags. Top spec has front LED, leather steering wheel, 6 speakers audio (low spec has 2 speakers), white rev counter with shift light and sport pedals. Top spec also has "smart entry and start".
Things of note:
Strut front, double wishbone rear suspension
Base halogens, optional HIDs on base trim, standard HIDs on high trim
LSD on all MT cars
Stability control standard
Only 2 speaker audio on base car
Here's a translated chart
Power/weight:
Weight:
Columns:
Top Section:
Second Section:
Fuel consumption:
13.4 km/l
31.52 mpg
50.72 km/g
Third Section:
Last Section:
More update:
Things of note:
LSD on all MT cars
