Baba!!!!!!!!!
É é...vai com um cabrio para a beira mar no Verão e é vê-las quase a saltar para dentro o carro. :risohistOriginally posted by dragonpt View PostTambém é fofo
As miudas vão todas querer um destes, em cabrio é carro de mulher BAH !
Sei do que estou a falar porque às vezes vou com um colega que tem um BMW E93 e como não estou habituado a tal fenómeno estou-me sempre a rir sozinho...tipo tolinho :lol
Aqui vai um artigo do FT86Club
Subaru (FHI), FR sport "BRZ" a small co-developed with Toyota Motor Corporation. Was also announced that the configuration is 3 and grade, "S" "R" "RA" to determine the release date on March 28.
The exterior and interior are introduced in the news and "see in the picture" already here, we want to introduce a mechanism for a little more deep.
■ Engine
"Said a low center of gravity" has it become a basic concept of BRZ. Its benefits along with the two points it is possible to reduce the role, that draw the full power of the tire. In other words, with or without hard suspension settings than necessary, or to install a high-grip tires, a translation can pursue handling performance.
However, it's easy only if written as "low center of gravity" just, quite difficult when it comes to the actual form. If the BRZ, FA20 engine of adoption "D-4S and the next generation, horizontally opposed" is that its core. As you know, the main stream of the company have just handed over to the third generation from FB20 and if Subaru EJ20 fan. Say it has been positioned has been newly developed and FA20-only (so far) there is a dare, and the car is BRZ & 86 with the more important role.
FA20 is a big point of, and specially designed intake manifold (hereinafter, intake manifold) and exhaust manifold (hereinafter, the exhaust manifold), but the adoption of thin oil pan it. This will clarify the features of the high center of gravity horizontally-opposed engine is lower than the engine originally series. And has achieved a very low center of gravity height and 460mm, the minimum ground clearance of 130mm. Also to the rear center position of the engine at the same time. Is also offset to the rear 240mm compared to the new Impreza, on the axle of the front wheel was almost. Weight distribution when you are around the front seat and ride 2 53:47 This, you can enjoy the fun of unique and FR.
■ Transmission
There are two types of transmission and a 6-speed AT 6-speed MT. MT is a single cone synchro over triple-cone, a 4-speed to 6, in the range shift feeling daily rate has been increased from 1 to 3. AT is electronically controlled adaptive control was adopted. Adaptive control and determine what the road conditions and vehicle state from the accelerator opening, that control is performed in accordance with the intent of the driver. 3 provides a mode of "SPORT" "SNOW" "(manual) M", has become a mechanism, such as running can enjoy according to the situation by changing the degree of control interventions, respectively.
It has become a royal road to select the MT given the run, there is only one problem. It should be turned to what was assumed 205Nm (20.9kgm) / 6400 ~ 6600rpm which is the current engine torque capacity of the transmission. Would have been taken from the factor of safety to some extent, it would not matter if a little about, such as response to the large torque 422Nm (43.0kgm) / 4400rpm Impreza WRX STI is it has not been assumed, for example. But that the drive train, otherwise the propeller shaft and drive shaft and differential, and there is enough space in the AT it.
However, there is no problem at all levels, even if it is about fine-tuned 6-speed MT. So there is a commensurate need to put hand to the engine if you plan to give more power and torque, there is a story about "Me and the brothers are also enhanced transmission if you do up there." Paradoxically, it will also with a supercharger (MT vehicles) does not publish unless you solve this problem
■ Suspension
The same combination, such as front suspension Impreza / McPherson strut, rear and / Double wishbone. However, the details are quite different.
Strut front cross member and lower arm employs a new shape. Reverses the orientation of the front and rear lower arm, and become the front side mount position, significant changes have been made. In addition, the attention also to the coil spring. If the front, because the bottom is above the tire mount, spring rate patterns earn you reduce the number of generally larger diameter wound. But, placed inside the tire diameter in bottom mount suppressing the BRZ. He has achieved a sporty style reduces the height of the front hood.
Newly designed rear sub-frame. As well as to optimize the suspension geometry, which enables deployment of large-capacity def.
O celica se a vida o permitir nunca sera vendido,eu até preciso de comprar um carro (a familia vai ter um novo membro ;) ) mas não sera o gt86 !!!Originally posted by William_1991 View PostObrigadinho por apoiares a malta...assim já nem desespera tanto a espera do test-drive nem nada.... :lol
Mas e na semana a seguir? Fazer encomenda para substituir o Celica? :assobio
Ya, na boa. Mas caso não saibas, (eu sei que sabes) foi pra despachar o Golf.Originally posted by FastPeter View PostNão sei onde está a graça...
Posso fazer piadas sobre o Swift?
Disse, porque até meteste o GTi á venda..:pLast edited by AE86Driver; 07-03-2012, 19:53 PM.
"Toyota boring era is over" e "Every Toyota should be more exciting, not only the GT 86 i can promisse you" foram 2 excelentes comentários!!!
Só ainda não vi muito isso no novo Yaris mas parto do inicio que será então a partir de agora e o proximo Auris esteja já incluido.... :assobio
Mas sem duvida que estão a promover o carro muito bem!! Quem me dera a mim conseguir um destes!!!
